Lee Mac Posted June 16, 2009 Posted June 16, 2009 By request from this thread: http://www.cadtutor.net/forum/showthread.php?t=37199 I have created an Elevation Marker, using the same programming methods as used in the above thread. ;;;==========================[ MacElev.lsp ]=========================== ;;; Author: Copyright© 2009 Lee McDonnell (Lee Mac) ;;; (Contact @ CADTutor.net, The Swamp.org) ;;; Version: 1.0 June 13, 2009 ;;; 2.0 June 14, 2009 ;;; 3.0 June 16, 2009 ;;; Purpose: To Align an Elevation Marker to a Curve ;;; Sub_Routines: getpoint_or_text.lsp by Charles Alan Butler (CAB) ;;; ;;; Additional Features: ;;; Use +/- to Alter Text Offset ;;; Use "P" to toggle perpendicularity ;;;==================================================================== (defun c:MacElev (/ *error* doc spc tmp tStr ent cObj tObj gr cPt pt cAng lAng BsEl ; *Mac$Str* } ; *Mac$tOff* } Global Variables ; *Mac$Per* } ) (vl-load-com) ;; Error Handler (defun *error* (msg) (and tObj (not (vlax-erased-p tObj)) (vla-delete tObj)) (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")) (princ (strcat "\n<< Error: " msg " >>"))) (princ)) ;; Check for Locked Current Layer (if (eq 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar "CLAYER")))))) (progn (princ "\n<< Current Layer Locked >>") (exit))) ;; Get Space & Doc (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) ; Vport (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) ;; Set First-time Defaults (or *Mac$Str* (setq *Mac$Str* "text")) (or *Mac$tOff* (setq *Mac$tOff* 1.)) (or *Mac$Per* (setq *Mac$Per* (/ pi 2.))) (if (setq bsEl (cadr (getpoint "\nSelect Base Elevation: "))) (progn ;; Get Text String (while (setq tmp (getpoint_or_text 2 (strcat "\nSelect Level Curve or Specify Text <" *Mac$Str* ">: "))) (cond ((eq "" tmp)) ((eq 'STR (type tmp)) (setq *Mac$Str* tmp)) ((vl-consp tmp) (setq cObj (vlax-ename->vla-object (car tmp)) *Mac$Str* (rtos (- (cadr (vlax-curve-getClosestPointto cObj (cadr tmp))) bSEl))))) (setq tStr *Mac$Str*) (or tSze (setq tSze (getvar "TEXTSIZE"))) ;; If No Curve Selected (if (not cObj) (while (progn (setq ent (nentsel "\nSelect Curve: ")) (cond ((and (vl-consp ent) (vl-position (cdr (assoc 0 (entget (car ent)))) '("LINE" "LWPOLYLINE" "POLYLINE" "ARC" "SPLINE" "CIRCLE" "ELLIPSE" "XLINE"))) (setq cObj (vlax-ename->vla-object (car ent))) nil) ; Exit Loop (t (princ "\nMissed, Try Again...")))))) ; Keep in Loop ;; Create Text Object (vla-put-alignment (setq tObj (vla-addText spc tStr (vlax-3D-point '(0 0 0)) tSze)) acAlignmentMiddleCenter) ;; Place Text (while (or (and (setq gr (grread t 15 0)) (eq (car gr) 5)) (and (eq 2 (car gr)) ; Keyboard (vl-position (cadr gr) '(43 ; + 45 ; - 61 ; + (as =) 80 112)))) ; P/p (cond ((and (eq 5 (car gr)) (listp (setq cPt (cadr gr)))) (setq pt (vlax-curve-getClosestPointto cObj cPt) cAng (angle pt cPt) lAng (+ cAng *Mac$Per*)) ;; Correct Angle (cond ((and (> lAng (/ pi 2)) (<= lAng pi)) (setq lAng (- lAng pi))) ((and (> lAng pi) (<= lAng (/ (* 3 pi) 2))) (setq lAng (+ lAng pi)))) (vla-move tObj (vla-get-TextAlignmentPoint tObj) (vlax-3D-point (polar pt cAng (* tSze *Mac$tOff*)))) (vla-put-Rotation tObj lAng)) ((eq 2 (car gr)) (cond ((vl-position (cadr gr) '(43 61)) (setq *Mac$tOff* (+ (/ tSze 10.) *Mac$tOff*))) ((eq (cadr gr) 45) (setq *Mac$tOff* (- *Mac$tOff* (/ tSze 10.)))) ((vl-position (cadr gr) '(80 112)) (setq *Mac$Per* (- (/ pi 2.) *Mac$Per*))))))))) (princ "\n<< No BasePoint Specified >>")) (princ)) ;;;=======================[ getpoint_or_text.lsp ]======================= ;;; Author: Copyright© 2005 Charles Alan Butler ;;; (Slight Modification by Lee McDonnell) ;;; Version: 1.0 Dec. 12, 2005 ;;; Purpose: To get user entered text or picked point ;;; Sub_Routines: -None ;;; Requirements: -ctype is the cursor type ;;; 0 Display the normal crosshairs. ;;; 1 Do not display a cursor (no crosshairs). ;;; 2 Display the object-selection "target" cursor ;;; -prmpt is the user prompt, start it with \n ;;; Returns: - picked point or ;;; the user entered text or ;;; "" for Enter Key ;;; nil for Escape Key ;;;====================================================================== (defun getpoint_or_text (ctype prmpt / char code data result flag p str) (vl-load-com) (vl-catch-all-apply '(lambda () (setq flag t str "") (princ prmpt) (while flag (setq p (grread t 15 ctype) code (car p) data (cadr p)) (cond ((= code 3) ; clicked point ; {Modification} (if (and (setq result (nentselp data)) (vl-position (cdr (assoc 0 (entget (car result)))) '("LINE" "LWPOLYLINE" "POLYLINE" "ARC" "SPLINE" "CIRCLE" "ELLIPSE" "XLINE"))) (setq flag nil) (princ "\nMissed, Try Again..."))) ; {End of Modification} ((= code 2) ; keyboard (setq char data) (cond ((<= 32 char 126) (princ (chr char)) (setq str (strcat str (chr char)))) ((= char ;; backspace was hit .. go chop off a character (and (> (strlen str) 0) (princ (strcat (chr " " (chr )) (setq str (substr str 1 (1- (strlen str)))))) ((= char 13) (setq result str flag nil)))))))) result) ;| ;;;¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,; End of Program Code ;;;¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,; |; Quote
NH3man! Posted June 16, 2009 Posted June 16, 2009 Will try it in the morning. I can't get 2009 to stay stable with Windows 7 now. I am not sure what happened but it keeps fatal error anytime I select something. Thanks Lee Quote
Lee Mac Posted June 16, 2009 Author Posted June 16, 2009 Hmmm... coincidently, could be related to this thread... http://www.cadtutor.net/forum/showthread.php?t=37278 Quote
NH3man! Posted June 17, 2009 Posted June 17, 2009 I don't think so Lee. I am running the same at work (2009) and have had little trouble unless I am working with 25mb drawing or larger. We have 2010 but have not switched do to not knowing it if is better or the later. I see you are using 2010 now, what operating system are you using it with? Quote
Lee Mac Posted June 17, 2009 Author Posted June 17, 2009 I see you are using 2010 now, what operating system are you using it with? I am running Windows Vista Home Premium (SP2) - also, 2010 is the students version. Quote
