I did a search for a similar thread but with no luck.
Anyway... I was hoping to find a thread that talked about whether or not it is possible to create a lisp that will open up a specific folder. Kind of like a command that has within it a search path.
Now when I want to go to this folder I have to browse through several others before I get to the one I want. I would like to be able to type in a command and it would magically open up to the folder I need... Unfortunately I have no idea how in depth of a routine this has to be or how to even begin writing it.
Something that may help, is that it is always the same folder that I need... So since it is always the same folder I am hoping it doesn't have to be as complex.
Thank you in advance for any advice/help any of you have :)
  • Replies 20
  • Lee Mac
    6
  • Se7en
    5
  • MFish
    5
  • CADkitt
    2
How about?
(if
   (= (getvar 'dwgtitled) 1)
   (startapp "explorer" (getvar 'dwgprefix))
How about?
(if
That makes good sense... I am having trouble remembering exactly what I need to get the routine going though. Like the command I would use to get it started once it is loaded. :unsure:
Sorry about my lack of knowledge I am still in the basic stages of using Lisp routines and such. :(
Here it is. Ive taken the liberty to name the command `OPENEX' but you can name it anything you want by changing it (leave the "c:" and the "( / )" parts).
(defun c:OpenEX ( / )
 (if
 (if
Oh okay! I will give that a shot, thank you very much!
Once you get it going, dont forget to drop it in your appload startupsuite so you can access it from any drawing. Also I would shorten the OpenEx to OEX just to make it quicker to type at the command line...
nice S8.
Your welcome very much.
nice S8.
That is a nice suggestion, thank you!
Okay, I tried using it and the first time I received back a nil response... Then I tried inserting the file path into the routine and it came back with error bad argument.
Here is the file path that I inserted, I am sure you will know what I did wrong...
(defun c:OEX ( / )
(if
(= (getvar 'G:\Automation\Drawing Patterns\AutoCAD STD\Library\Panel\Square D\PLC) 1)
(startapp "explorer" (getvar 'G:\Automation\Drawing Patterns\AutoCAD STD\Library\Panel\Square D\PLC))
The code will only follow through when the drawing has been saved - i.e. when dwgtitled = 1.
If it is the same thing you need everytime - maybe this:
(defun c:OEX ( / )
(startapp "explorer" "G:\\Automation\\Drawing Patterns\\AutoCAD STD\\Library\\Panel\\Square D\\PLC")
Otherwise perhaps this?
(defun c:getfile  (/ file)
 (setq file
        (if load_file
          (getfiled "Select File" load_file "" 2)
          (getfiled "Select File" "" "" 2)))
 (or (not file) (setq load_file file)))
1. Paths have to have either double slashes like: "C:\\Temp\\My Dir\\" or a forward slash like: "C:/Temp/My Dir/"
Yes that will only work if the drawing has been saved. And you should have a problem with it. I dont know why it would give you an error.
2. Lee Mac's last code: I can see that stupid `IF this then that then OR' has infected this forum as well. ...I'll have to correct that. :P
Can't believe I missed the single backslash - nice spot Se7en... :oops:
Haha - whats wrong with a use of a good ol' OR...
either that or its (if (not this), then this...)
Nothing when preforming a boolean check.
 (setq file
  ;; bind variable FILE to results from GETFILED
        (if load_file
          ;; where did this var come from?
          ;; Are you using a global var called load_file?
        ;; the IF statement will return the results from GETFILED
 (or ; Run boolean; stop on first non nil statement
   (not file)
   ;; 1. if the variable FILE is bound to nil then
   ;; 2. if the variable is bound then
   ;; 1. bind the variable LOAD_FILE to nil
   ;; 2. never evaluate this statement
Sorry, I dont really follow your logic in this one.
Hmmm... I followed it like this:
 (setq file
        (if load_file
          ;; where did this var come from? [b][color=Blue]<<-- Using it as a global Variable[/color][/b]
          ;; Are you using a global var called load_file?  [b][color=Blue]<<-- Yes[/color][/b]
   (not file)
[color=Red][b]    ;; 1. if the variable FILE is bound to nil then (not file) returns T
   ;; 2. if the variable is bound then  (not file) returns nil[/b][/color]
[color=Red][b]    ;; 1. don't evaluate this statement
   ;; 2. bind its value to the global variable[/b][/color]
That's good to know, I wasn't aware of the backslash issue.
And just an update, both of the routines work flawlessly! And I must tip my hat to you both! That's a great help, and thank you for being so quick about everything :)
Not sure what you require but if this helps well and good.
(defun c:JOB ()
(setq jobnumber (getstring "\nTYPE JOB NUMBER"))
(setq first2chars (substr jobnumber 1 2))
(setq jobfolder (strcat "[url="file://\\Jobs"]\\Jobs[/url] 20" first2chars))
 (setq path1 (strcat "R:"))
 (setq path2 (strcat "\\"))
 (setq FullPath (Strcat path1 jobfolder path2 jobnumber))
 (startapp "Explorer" FullPath)
(defun c:JOB ()
(setq jobfolder (strcat "[url="file://%5C%5CJobs"]\\Jobs[/url] 20" first2chars))
Russell, I think that code is quite specific for your purpose - but thanks for the post all the same :)
  • 1 year later...
I'm trying to make a command for in toolpallets so you can open the folder of the current tool pallet.
but this doesn't work:
  • ^c^c(startapp "explorer" "I:\\Engineering\\Equipment\\name\\01010")
  • ^c^c(startapp "explorer" "I:\Engineering\Equipment\name\01010")
  • ^c^c(startapp "explorer" "I://Engineering//Equipment//name//01010")
  • ^c^c(startapp "explorer" "I:/Engineering/Equipment/name/01010")
I rather not use a lisp because the tool pallets get distributed true the network.
Found this similar thread: http://www.eng-tips.com/viewthread.cfm?qid=13388&page=207
Doesn't really have an solution except using your internet browser.
For a macro, what about this:
_.browser;"I:/Engineering/Equipment/name/01010"
I would like to hear if it works!
Browser works fine only if you use internet explorer if you have chrome you get the dir in chrome and I guess the same results in fire-fox. I now use this and have the chrome ie tab extension set up to automatically load file://. It works but not without extra work. Maybe there is a way to force IE on open?
