I need a lisp routine that will do the following...
1) Click on a block with 2 attributes:
NODE_ID
AMP_ID
2) Click on another block to update 2 attributes:
NODE_ID (This should equal NODE_ID from first block)
DEVICE_NUMBER (This should equal AMP_ID from first block)
Thanks for any help!
Hahah, you and your blocks... :P
Would you like the second selection to be for multiple blocks? or Automated? or would you rather just a simple two click job :)
Yes. It's me again. I have this large project just about finished.
I need to select multiple destination blocks at one time.
Thanks again for your help.
Quickly written and untested!
(defun c:blkupd     (/ bEnt aEnt eLst aNode aAmp ss EntLst attEnt attEntLst)
 (if (and (setq bEnt (car (entsel "\nSelect Block to Retrieve Attribute Values >   ")))
      (= "INSERT" (cdadr (entget bEnt))) (= 1 (cdr (assoc 66 (entget bEnt)))))
     (setq aEnt (entnext bEnt))
     (while (= "ATTRIB" (cdadr (setq eLst (entget aEnt))))
   (cond ((= "NODE_ID" (cdr (assoc 2 eLst)))
          (setq aNode (cdr (assoc 1 eLst))))
         ((= "AMP_ID" (cdr (assoc 2 eLst)))
          (setq aAmp (cdr (assoc 1 eLst)))))
   (setq aEnt (entnext aEnt)))
     (if (and aNode aAmp)
     (if (setq ss (ssget (list (cons 0 "INSERT")(cons 66 1)
       (if    (getvar "CTAB")(cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE")))))))
         (setq EntLst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
         (foreach e  EntLst
       (setq attEnt (entnext e))
       (while (= "ATTRIB" (cdadr (setq attEntLst (entget attEnt))))
         (cond    ((= "NODE_ID" (cdr (assoc 2 attEntLst)))
            (entmod (subst (cons 1 aNode) (assoc 1 attEntLst) attEntLst)))
           ((= "DEVICE_NUMBER" (cdr (assoc 2 attEntLst)))
            (entmod (subst (cons 1 aAmp) (assoc 1 attEntLst) attEntLst))))
         (setq attEnt (entnext attEnt)))))
       (princ "\n<!> No Blocks Selected <!>")))
   (princ "\n<!> Selected Block Doesn't Contain Required Attributes <!> ")))
   (princ "\n<!> No Block Selected <!>"))
 (command "_regenall")
 (princ))
You have done it once again!
Thanks agin for your help.
