Creating surfaces from survey points
HI
I am having problems creting surfaces from points I imported into the drawing.
The surface form triangles but the points stay on the plane z=0
Also I get errors that crossed a breakline.
when rebuilding the surface after deleteing the breaklines ( i deleted some ) it forms a surface but the surface forms on the points with elevation of 0.
how do I fix this problem any help is appreciated.
My main pupose of the drawing is to create a drainage ditch and calculate the earthwork volume.
the process I think is correct but not sure
1) Import points from the txt file
2) create a surface from existing countours
3) Create a feature line along the path of the alignment
4) Create a alignment from the feature line
5) create a assembly for the desire design
6) create a corridor on the proposed alignment
7) compute the earthwork volume
Any help will be apprciated
Thanks
Paul
You imported points from a text file and the points are now in Civil 3d, but all have 0 z value? It sounds like the points were not assigned elevational values. Please post the text point file for evaluation if you don't mind.
When you create a surface from points the contours should be the result of those points. You should not create the existing surface from contours as you said in number 2 unless you have little or no other existing data to use.
To create the ditch you can use feature lines and grading tools or create an alignment and corridor. You may even use a hybrid of the two. I would be inclined to create a feature line as the flow line (center line) of ditch, assign elevations to said feature line, and then use the grading tools to grade out in both directions at the desired slopes.
If you will need to run sections of the ditch then a corridor might be best suited.
I don't think it allows attachments if you have less than 10 posts. Just copy and paste in a portion of the file in your post.
Hi Rusty
sorry about that here are some points I imported
2,20809497.9720,1605059.4290,5456.2200,CALC INVERT
111,20802118.2880,1608738.2280,5504.0900,KTNX 1
112,20807839.5720,1605720.2410,5471.6400,RW14
113,20796768.6210,1610352.2310,5548.5500,RW32
1000,20807839.5420,1605720.2680,5471.6600,RW14
1001,20807839.5460,1605720.2650,5471.6400,RW14 CHK
1002,20796768.6190,1610352.2160,5548.5700,RW32
1003,20796768.6310,1610352.2210,5548.5600,RW32 CHK
1004,20796768.6210,1610352.2210,5548.5700,RW32 CHK
1005,20798246.4380,1615390.2270,5513.8500,CP MASTERS
1006,20798246.4220,1615390.2290,5513.8500,CP MASTERS CHK
1007,20790359.3340,1613497.1290,5632.8300,CONTRAVES 21
1008,20790359.3170,1613497.1340,5632.8400,CONTRAVES 21 CHK
1009,20807095.9200,1607674.0390,5462.0900,WEST TARGET
1010,20807095.9190,1607674.0240,5462.1400,WEST TARGET CHK
3000,20797398.2880,1612067.0830,5518.6700,EDGE CONC / EP
3001,20797403.2670,1612077.9460,5518.4400,EDGE CONC / EP
3002,20797406.9280,1612087.5280,5518.1900,AP CONC / EP
3003,20797406.8440,1612087.6910,5518.2200,AP CONC / EP
3004,20797407.5360,1612089.7350,5518.1400,AP CONC / EP
3005,20797408.1770,1612091.1280,5518.0600,F/L
3006,20797408.5280,1612091.6870,5518.5600,BFC
3007,20797391.1550,1612098.8930,5518.7100,BFC RET
3008,20797390.9140,1612098.3160,5518.2000,F/L
It looks like the z values are fine there.
When you create the surface and add these points to the surface does it give you contours?
If you go into the Surface Properties (select surface > right-click > surface properties) and look at the surface statistics what does it say under the minimum and maximum elevations?
no
its does not the elevation remain at minimum and maximum of zero elevation,. and the points remain at the zero elevation
paul
Make sure you are picking the right option when importing PENZC is different to PEN or PNE.
That was also my next thought. You may have selected the wrong point format.
