Flatten alternatives
Just a follow up to the inquiry on the Flatten command.
Is there a way to use set all entities in a drawing to elevation 0? like moving them all to Z=0
like the flatten command but all entities in one command including blocks, hatches, etc
TIA:D
  • Replies 28
  • Cad64
    5
  • nocturne00
    5
  • skipsophrenic
    3
  • merdrignac
    3
I found this routine somewhere, years ago, and have been using it ever since. It works much better than the Flatten command.
(defun c:flat (/ total-nabor)
(vl-load-com)
(if
(setq total-nabor (ssget "x" '((410 . "model"))))
(setq total-nabor
(mapcar 'vlax-ename->vla-object
(mapcar 'cadr
(ssnamex total-nabor)))
(foreach i '(1e99 -1e99)
(mapcar (function (lambda (x)
(vla-move x
(vlax-3d-point (list 0 0 0))
(vlax-3d-point (list 0 0 i)))
)) total-nabor )))
wow, so nice, works like a charm :D
this sure beats the flatten command hehe.
ever experienced errors or bugs using it?
thanks bro
No, I don't think I've ever had any problems with it. I'm not saying it's perfect, but it's pretty good, and it has always worked for me. But I also know there's a first time for everything, so if you experience any problems with it, post back and maybe one of the lisp guys can sort it out.
Good routine. I wonder if this will correct the "entities not coplanar" crap I have to deal with from time to time. That's the only time I use the FLATTEN command but I can't stand using it. It doesn't stay the same distance.
Likewise,in civil 3d its so fraustrating to join or fillet plines end come up with "lines are not coplanar" result. when u check the line elevations you just get a + or -0.0026 line elevation, whats worse is almost half of the entire drawing is set to this elevation... really fraustrating :x
anyways, the lisp routine really works. will report any bugs if ever.
Thanks again :D
just so i know (have been redirected here for an answer) once loaded do i just type the word "flat" in command bar?:unsure:
thnx, i'll give it a try
Try this button macro:
C^C_move;_all;;0,0,0;0,0,1e99;_move;_p;;0,0,0;0,0,-1e99;
Quick and simple
Edited by SLW210
Code Tags
Question on that routine. How do I put it to use? I've never set up commands before.
Makes perfect sense. I followed the directions. Copied and pasted it. put it in the same place where all my lisp routines are. So it's loading....But when I type "Flat" noting happens. Says it's an unknown command. Anyone have any idea what I might have done wrong?
All depends on which version of Autocad you use. Is Building Systems an autocad varient?
Yep its autoacad,,, better known as ABS (AutoCAD Building Systems)
It should work since it is basically still autoCAD based. all the basics of it are there...
Did you save it as flat.lsp?
Hi Cad;
stumbled on a small glitch when using flat. i dont know if you already came accross this but it seems when I use the lisp it affects dynamic blocks. the command changes the Properties>Geometry>ScaleZ of the block to 0 and thus making the Dynamic block... non dynamic;(thanks to Ipseifer for figuring this out by the way)
all dynamic functions are not usable although in BEDIT the dynamic functions are still present, but not usable anymore unless the ScaleZ factor is changed to 1 :) .
Hope you guys can help me with this coz ive come to use this Lisp quite often now.
TIA
The macro I posted was meant to be attached to a button on a button menu. You have to open customise, create a new command, and add the macro and apply. when you click on the button the command to reduce everything to zero in the z plane, is executed with no further imput required. For details on customising refer to Autocad 'Help'.
Hope that helps
  • 4 years later...
Hello the script above works great.. however I am recieving the following error message:
; error: Automation Error. Not allowed for this proxy
Any ideas ? :D
