I have created a batch program in VBA that opens drawings from a list and does an bunch of stuff to the drawing to get it ready to be issued. The last thing I want it to do is print an 11X17 copy of the drawing for our binders but I can not figure out how to do this in VBA.
Any help would be greatly appreciated!
  • Replies 22
  • CmdrDuh
    9
  • ML0940
    7
  • -KarL-
    6
  • veranco
    1
Posted Images
Karl
Have you looked into Plot Configurations in VBA?
I don't really have a good example but if you go to VBA Help and type that in, there will likely be an example that will get you going
ML
OK, I just checked the help in VBA
You will likely need to add a plotconfig or possibly just apply this method to an existing plotconfig
This code is from The VBA Help Screen
Sub Example_GetPaperSize()
'This example gets the width and height of the default paper size for 'your system.
Dim PaperWidth As Double, PaperHeight As Double
ThisDrawing.ActiveLayout.GetPaperSize PaperWidth, PaperHeight
MsgBox "The default paper size is " & vbCrLf & _
 "Width: " & PaperWidth & vbCrLf & _
 "Height: " & PaperHeight
 End Sub
ML
The help menu I have does not list AutoCAD commands, only basic VBA commands.
I am looking for a way to create a new plot configuration and then print the drawing using that configuration rather than one already in the drawing but I haven't been able to figure that part out.
this should get you started. Are you wanting to hard code your paper size or pass it as an argument?
Public Sub SetupAndPlot(ByRef Plotter As String, CTB As String, SIZE As String, PSCALE As String, ROT As String)
     Dim Layout As AcadLayout
     On Error GoTo Err_Control
     Set Layout = ThisDrawing.ActiveLayout
     Layout.RefreshPlotDeviceInfo
     Layout.ConfigName = Plotter    ' CALL PLOTTER
     Layout.PlotType = acExtents
     Layout.PlotRotation = ROT    ' CALL ROTATION
     Layout.StyleSheet = CTB    ' CALL CTB FILE
     Layout.PlotWithPlotStyles = True
     Layout.PlotViewportBorders = False
     Layout.PlotViewportsFirst = True
     Layout.CanonicalMediaName = SIZE    ' CALL SIZE
     Layout.PaperUnits = acInches
     Layout.StandardScale = PSCALE    'CALL PSCALE
     Layout.ShowPlotStyles = False
     ThisDrawing.Plot.NumberOfCopies = 1
     Layout.CenterPlot = True
     If SIZE = "ARCH_expand_C_(24.00_x_18.00_Inches)" Then
           Layout.ScaleLineweights = True
     End If
     ThisDrawing.Regen acAllViewports
     ZoomExtents
     Set Layout = Nothing
     ThisDrawing.Save
Exit_Here:
     Exit Sub
Err_Control:
     Select Case Err.Number
     Case "-2145320861"
           MsgBox "Unable to Save Drawing- " & Err.Description
     Case "-2145386493"
           MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style"
     Case Else
           MsgBox "Unknown Error " & Err.Number
     End Select
End Sub
I am passing paper size, ctb, rotation, pc3 etc to this function which sets up and plots.
this is the function that pass the info
Public Sub Vendor1117()
     Call SetupAndPlot("11x17Draft.pc3", "11X17-CHECKSET.ctb", "ANSI_B_(11.00_x_17.00_Inches)", acScaleToFit, ac90degrees)
     ThisDrawing.Plot.PlotToDevice
           ThisDrawing.Close (True)
End Sub
CmdrDuh
That looks about like what I need, just a few questions though:
1. Does it need a .pc3 file or can it be a network printer name?
2. Will it print all layouts in the drawing or only the active layout?
It can be the network printer name, and as written, only the active layout. However, it can be modified to print all layouts, BUT, you have to know that all the layouts are good. What I mean by that is the default template (at least on my machine) has 2 layout tabs when I start a new drawing. I usually don't use the second layout, and I delete it. HOWEVER, if you were to print all layouts, you might get a blank page sent to the printer
If you look at this picture, you can see I highlighted a network printer. I turned on the Locals window to see the current configuration as I step through the code.
Can I attach a PNG file?
Hey CmdrDuh,
Good to see you again.
Karl, in The VBA Editor help, there is a button for Object browser; after you click that, there will be a text box. In there, type plotconfig, that is you will see the code examples and methods.
I am not saying that every thing you will need is there but it would def. get you started in the right direction; not only for this but many other things as well.
Cool, I think I will be able to use this later on as well.
Cmd, if you were going to use the function, in what part of the first sub would you call it from?
Cmd, didn't you have code for setting the default printer?
Could that also be used with this?
To expound on Karl's question; Karl CMD is using the active layout in his code, do you have a specific layout name?
If so, this code could be set to that layout, specifically. I think that may be what you are looking for?
ML
it actually gets called from the second shorter piece of code
I have code to set the default printer, but its for windows not acad.
As for calling the layout name, you could test for any layout NOT "layout*" and print that, assuming you name your layouts
I have a LISP routine I use to call printing from keyboard, or macro from button.
Our templates are setup with only one layout tab so if there are more layout tabs in the drawings they will also need to be printed.
OK, so we could change it to be for all layouts NOT named Model, print
Do you think you can tweak it from here or do you need help?
CMD
Please correct me if I am wrong; that is interesting.
It looks like you are calling the first sub up from the second sub.
So, would you actually run the Public Sub Vendor1117 Sub first then?
I suppose I can do a test drawing and try it, I was just curious after looking at it
Thanks
ML
yes, the CALL statement calls the second sub and passes the arguments to the second sub. That way I have 1 routine to print any number of ways. I have like 12 of the short versions, which all call the main sub and pass the settings I want.
I give the code a try a see if I can get it to work, otherwise I will be back.
Thanks a lot for all your help!
That is a cool approach CMD with the function part
Yes, that is what I would do as well.
If the layouts are named, then one gets deleted, "I think" a new one called Layout1 will be recreated. So, filtering out the name Layout may not be the best way to approach it.
Filtering out Model and looping through all layouts (in my opinion) would probably be the best attack, if you truly want to print all layouts.
If the layouts are named, I would set a reference to the specific layout(s) name.
ML
I got it to work, here is how I got around the multiple layouts
     For x = 0 To Drawing.Layouts.Count - 1
       Set Layout = Drawing.Layouts(x)
       Layout.StandardScale = PSCALE       ' CALL PSCALE
       Drawing.ActiveLayout = Layout
     Next x
