Polyline to Block
John E Green
Hi,
I hope someone can help me!!! I have been searching high and low for an Autolisp routine to convert a polyline to a block, I found some that work but what I want to do is use the boundry command to create a ployline round a room, then convert the polyline to a block. I can create the polyline fine via Autolisp and I can convert an existing polyline to a block, but when I try and put the two together it goes all wrong.
Any help or pointer would be very helpful.
John
This should convert selected objects to blocks:
(defun c:obj2blk (/ BNME ENT I PT SS SUB)
 ;; Lee Mac  ~  11.02.10
 (cond (  (not (setq ss (ssget '((0 . "~VIEWPORT"))))))
       (  (while
              (setq bNme (getstring t "\nSpecify Block Name: "))
              (cond (  (not (snvalid bNme))
                       (princ "\n** Invalid Block Name **"))
                    (  (tblsearch "BLOCK" bNme)
                       (princ "\n** Block Already Exists **"))))))
       (  (not (setq i -1 pt (getpoint "\nSpecify Base Point: "))))
       (t (entmake (list (cons 0 "BLOCK") (cons 10 pt) (cons 2 bNme) (cons 70 0)))
          (while (setq ent (ssname ss (setq i (1+ i))))
            (entmake (entget ent))
            (and (= 1 (cdr (assoc 66 (entget (setq sub ent)))))
                 (while (not (eq "SEQEND" (cdr (assoc 0 (entget (setq sub (entnext sub)))))))
                   (entmake (entget sub)))
            (entdel ent))
          (entmake (list (cons 0 "ENDBLK") (cons 8 "0")))
          (entmake (list (cons 0 "INSERT") (cons 2 bNme) (cons 10 pt)))))
 (princ))
Hi Lee,
Thanks for such a prompt reply, I think I can see where I was going wrong now. I'll try you routine later.
Many thanks
