I'm trying to teach myself ACAD2004 and am working through some practice sheets and I've hit a problem that I just cannot solve.
I want to draw an arc (that according to the drawing I am working from is part of a circle with a 50mm radius) between a circle and the corner point of a line.
I've attached a .jpg and my .dwg if someone can advise me how to do it I'd be grateful.
I suspect that it is not entirely straight forward and a little ACAD voodoo will be involved.
handle & spanner.dwg
not sure there is a command for this but you can work it out using your radius information, like this.
1, draw a circle of radius 50mm with its centre on the end of the 16mm straight line near the middle of the handle
2, draw a circle of radius 60mm with its centre on the centre of the radius 10mm bulb at the end of the handle, (60mm is your connecting arc radius + the radius of your bulb)
3, where the 60mm circle intersects the 50mm draw a third circle with a radius of 50mm
you should now be able to trim the last circle you have drawn to achieve your goal.
hehe it all comes with experience i was trained on the old drawing boards where we had to construct everything :), ah the good old days lol, what a pain.....
Groutie, I don't think it has a use! :) It's just an exercise sheet I was given for drawing practice as I'm an AutoCad newbie. I like your 3D drawing. Waay beyond my ability at the moment though but hopefully I'll be there soon.
  • 2 years later...
Look into the Tan Tan radius option under the circle command...See if that helps
Thankyou works a treat minus the fiddling cheers...
I tried this in the first drawing but it didnt help
try this.
Ive used steps in cad
Strange When i tried this it didn't work??? I'll try it later on,
There is a slight difference between the 60-50mm cirlce solution and the arc start end radius.
lol what a funkie lookin tool....not sure how useful it would be
1. make a line bet. the circle and and the rectangle to join your arc.
2. make a perpendicular line with a length of 50mm
3. draw a circle with Ø50mm
4 draw a line end-end to the drawn upside -down "t"
5 move the circle intersecting the diagonal line, eithe of the diagonal lines.
6 trim.:oops:
