guyzen2004 Posted September 3, 2008 Posted September 3, 2008 Is it posibble to make two viewports of the same drawing have different colors and linetypes? I have this drawing wherein I used the general drawing as my key plan. The problem is I need to make the lineweight of my keyplan lighter than the general drawing. Quote
rkent Posted September 3, 2008 Posted September 3, 2008 Is it posibble to make two viewports of the same drawing have different colors and linetypes? I have this drawing wherein I used the general drawing as my key plan. The problem is I need to make the lineweight of my keyplan lighter than the general drawing. Starting with 2009, yes you can. Quote
Dipali Posted September 3, 2008 Posted September 3, 2008 I am able to do it in acad2008 LT also. double click inside your viewport & than open layer manager, so you will see extra options related to vp as shown here in screenshot. so you can asign different color,linetype & lineweight which will apply to that viewport only. Quote
smorales02 Posted September 3, 2008 Posted September 3, 2008 Dipali Is that something that was released in 08'? Does it work for xrefed layers? Quote
Dipali Posted September 3, 2008 Posted September 3, 2008 i am not sure, when was it introduced but it is availble in 2008LT AND yes it does work for xref layers as well. I alos discovered it recently while working on someone lese's drawing who had 20 layouts in one file. Quote
Cad64 Posted September 14, 2008 Posted September 14, 2008 It was first introduced in 2008. :wink: Quote
