There is a thread in the General area that I responded to about a routine for an electrical wire jumper. rkent posted a lisp that is almost what I need. I need to add a feature to the routine that would define the ltscale at .4072 in the beginning and then redfine it back to 1 at the end. If it would auto repeat that would be way cool.
Any takers on this? Thanks in advance.:)
JUMPER.LSP
  • Replies 24
  • Lee Mac
    10
  • Glen Smith
    4
  • Ryder76
    3
  • alanjt
    2
Hi Ryder,
I have slightly modified your code in that the Arc Radius may be specified at the top of the code.
I have also added an error handler :)
(defun c:jumper (/ *error* A B1 B2 BDIS ENT OV P1 P2 VL)
 (setq bDis 0.04072) ;; Arc Radius (Break Distance / 2.0 )
 (defun *error* (msg)
   (and ov (mapcar (function setvar) vl ov))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq vl '("CMDECHO" "OSMODE") ov (mapcar (function getvar) vl))
 (while (and (mapcar (function setvar) vl '(0 32))
             (setq p1 (getpoint "\nPick INTERSECTION: "))
             (setq ent (entsel "\nPick LINE TO BREAK: ")))
   (setq p2 (osnap (cadr ent) "_nea")
         b1 (polar p1 (setq a (angle p1 p2)) bDis)
         b2 (polar p1 (+ pi a) bDis))
   (setvar "OSMODE" 0)
   (command "_.break" b1 b2)
   (if (> a (/ pi 2.))
     (command "_.arc" b1 "_E" b2 "_A" 180.)
     (command "_.arc" b2 "_E" b1 "_A" 180.)))
 (princ))
Let me know if this works for you :)
What did I tell you Ryder? Want my next prediction?
Big hugs Lee - I love it - you're the best!:D
Predictions from a Quantum Mechanic are the best!:D
I saw the other thread last night just before putting the kids to bed. I knew that I wanted to grab the code for work, but promptly forgot the thread name. This morning I remembered that I wanted the code and that Ryder had posted on the thread, so I searched on her name. And I find that Ryder has already asked Lee to put in an error handler and he has polished the code. :D
I took the liberty of adding undo marks to the new code so each jumper can be undone rather than undoing the arc, then the break. Otherwise, I'm certain to get caught sometime with a broken wire and no arc to connect it.
Thanks to all!
(defun c:jumper (/ *error* A B1 B2 BDIS ENT OV P1 P2 VL doc)
 (setq bDis 0.1) ;; Arc Radius (Break Distance / 2.0 )
   (princ))
   (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
   (vla-startUndoMark doc)
   (setvar "OSMODE" 0)
   (if (> a (/ pi 2.))
   (vla-EndUndoMark doc)
 (princ))
Tweaked as requested :D
(defun c:jumper (/ *error* A B1 B2 BDIS DOC ENT OV P1 P2 UFLAG VL)
   (and uFlag (vla-EndUndoMark doc))
   (princ))
   (setq uFlag (not (vla-StartUndoMark doc)))
   (setvar "OSMODE" 0)
   (if (> a (/ pi 2.))
     (command "_.arc" b1 "_E" b2 "_A" 180.))
   (setq uFlag (vla-EndUndoMark doc)))
 (princ))
Thank you Lee, that works better than what I had. I have noticed that if I undo a jumper the OSNAPS are not set to the beginning values. I have always heard that phantom changes to your OSNAPS are often due to LISP's "misbehaving". But returning the OSNAPS has to be the last thing done in the LISP. How do you skip over returning the OSNAPS to the initial value, yet still allow the user to undo jumpers one at a time?
Glen
Ah yes - I suppose this is a workaround:
   (and msg (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*")
                (princ (strcat "\n** Error: " msg " **"))))
   (princ))
 (while (and (setq uFlag (not (vla-StartUndoMark doc)))
   (setvar "OSMODE" 0)
   (if (> a (/ pi 2.))
 (*error* nil)
 (princ))
IMO, I would not change the OSMODE to 32 and leave the user to make sure that Intersection is enabled - saves a lot of hassle. :)
You are wonderful!:)
Thanks Ryder :)
You might want to use the latest code posting, as we found a small glitch with the UndoMarks within the code - the UNDO caused the OSMODE to be set to the state it was before the first UndoMark. Hopefully the latest code resolves this issue.
Lee,
Is there a way to check if the line that is broken is a PLINE and if so, join the arc with the two segments created by the break? I often use PLINEs with a width greater than the default for my wires to set them apart from the other drawing elements. After using the jumper routine, I then have to go back through and do a PEDIT on each line and join them. This keeps the wire as a single entity in case of future moves, and also happily sets the width of the new arc to the same as the other segments of the PLINE.
I know that this request is beyond my abilities.
Glen
(*error* nil)
AHAHA. Welcome to the dark side. :wink:
Hahaha well, it just seemed easier in this case :)
Try this Glen, nothing fancy, and not much error trapping:
(defun c:jumper (/ *error* A AENT B1 B2 BDIS BENT DOC ENT OV P1 P2 UFLAG VL)
   (princ))
       vl '("PEDITACCEPT" "CMDECHO" "OSMODE") ov (mapcar (function getvar) vl))
 (setvar "PEDITACCEPT" 1)
             (mapcar  (function setvar) (cdr vl) '(0 32))
   (setvar "OSMODE" 0)
   (setq bEnt (entlast))
   (if (> a (/ pi 2.))
   (setq aEnt (entlast))
   (command "_.pedit" "_M" bEnt aEnt ent "" "_J" "" "")
 (*error* nil)
 (princ))
Just giving you a hard time. :)
   (princ))
   (setvar "OSMODE" 0)
   (if (> a (/ pi 2.))
 (*error* nil)
 (princ))
Almost, the arc is a pline and continuous with the pline, but the program (for the arc) doesn't pick up the initial width of the pline that is broken and arc inserted. (more dark side !)
S
This really is getting messy now... :geek: :(
(defun c:jumper (/ *error* A AENT B1 B2 BDIS BENT DOC ENT OV P1 P2 UFLAG VL O W)
   (princ))
   (setvar "OSMODE" 0)
   (if (> a (/ pi 2.))
   (if (eq "LWPOLYLINE" (cdr (assoc 0 (entget (setq ent (car ent))))))
       (setq w (vla-get-ConstantWidth (setq o (vlax-ename->vla-object ent))))
       (vla-put-ConstantWidth (vlax-ename->vla-object (entlast)) w)))
 (*error* nil)
 (princ))
   (princ))
   (setvar "OSMODE" 0)
   (if (> a (/ pi 2.))
 (*error* nil)
 (princ))
not messy, just PERFECT... thanks for making EE's happy !
