Leaderboard
Popular Content
Showing content with the highest reputation on 07/02/2024 in all areas
If you plan on doing university for architecture, you will probably have a good chance of landing employment, check with the university, lots of companies get students to work for them on a full time and/or part time basis, at least here in the USA. Getting some online experience and working through tutorials, etc. plus showing you are doing the schooling for a degree in architecture would go a long way toward getting hired. I am completely self taught for AutoCAD as well as 3D CAD and modeling, though I have a mechanical degree and started on board drafting, I started out working in machine shops and doing fabrication and welding. Forums like CADTutor, Autodesk and others are great for help when you hit any roadblocks along the way.1 point
Go a I7 and look for say a NVIDIA graphics card, maybe look at a AMD offering. We at one stage had to replace computers when we did a Acad upgrade as the inbuilt Intel graphics was a problem.1 point
You may be better using a entmake to create your style. 2 examples. You can do this as a defun for multiple dimstyles just set the variable to a value eg (cons 2 dname) (if (not (tblsearch "dimstyle" "TA-DIM-60")) (entmake (list (cons 0 "DIMSTYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbDimStyleTableRecord") (cons 2 "TA-DIM-60") (cons 70 0) (cons 7 "Arial") (cons 40 1.0) (cons 41 2.0) (cons 46 2) (cons 140 2.5) (cons 340 (tblobjname "Style" "Arial")) ) ) ) You dont have to have every single property. (entmake (list (cons 0 "DIMSTYLE") (cons 100 "AcDbSymbolTableRecord") (cons 100 "AcDbDimStyleTableRecord") (cons 2 Dim_Name) ;Dim style name (cons 70 0) ; Standard flag (cons 3 " [m]"); DIMPOST (cons 4 ""); DIMAPOST (cons 5 DIMBLK-Name) ;DIMBLK-Name of block instead of default arrowhead (cons 6 DIMBLK-Name);(cons 6 "ClosedFilled"); DIMBLK1 (cons 7 "Standard") ; text style name (cons 170 0) ;DIMALT-turns off alternate units (cons 40 dimscale) ;DIMSCALE-sets the overall scale factor applied to all dimensions (cons 41 Arrow_Size) ;DIMASZ-sets the size of the arrow/tick (cons 42 Extension_Line_Origin_Offset); DIMEXO (cons 43 Dimension_Line_Spacing); DIMDLI (cons 44 Extension_Above_Dimension_Line) ;DIMEXE-specifies how far to extend the extention line beyound the dim line (cons 45 0.0); DIMRND (cons 46 0) ;DIMDLE-sets the distance the dimension line extends beyond the extension line (cons 47 0.0); DIMTP (cons 48 0.0); DIMTM (cons 71 0); DIMTOL (cons 72 0); DIMLIM (cons 73 0) ;DIMTIH-controls the position of dimension text inside extention lines ;METTE IL TESTO DI QUOTA ORIZZONTALE (cons 74 0) ;DIMTOH-controls the position of dimension text outside extention lines (cons 75 1); DIMSE1 ;1 sopprime la linea di estensione, 0 la lascia (cons 76 1); DIMSE2 ;1 sopprime la linea di estensione, 0 la lascia (cons 77 1) ;DIMTAD-controls the vertical position of text in relation to the dim line (cons 78 3) ;DIMZIN-controls the suppression of zeros (cons 79 1); DIMAZIN (cons 140 Text_Height) ;DIMTXT-specifies the height of the text in the dim (cons 141 Center_Mark_Size); DIMCEN (cons 142 0.0); DIMTSZ (cons 143 0.5) ;DIMALTF-controls the scale factor for alt. units (cons 144 quote_scale); DIMLFAC ;scala di quota (cons 145 0.0); DIMTVP (cons 146 0.64); DIMTFAC (cons 147 Gap_From_dimension_Line_to_Text) ;DIMGAP-sets the distance from around the dim text (cons 170 0); DIMALT (cons 171 2) ;DIMALTD-controls the decimal places for units (cons 172 0) ;DIMTOFL-forces a line inside extension lines (cons 173 1); DIMSAH (cons 174 0); DIMTIX (cons 175 0); DIMSOXD (cons 176 256); DIMCLRD (cons 177 256); DIMCLRE (cons 178 256); DIMCLRT color of text (cons 179 0); DIMADEC (cons 270 2) ;DIMUNIT-sets the units format for all dims ;2 decimale ; 4architettonico (cons 271 Decimal_Places) ;DIMDEC-sets the number of decimal places of primary units (cons 272 Tolerance_Decimal_places); DIMTDEC (cons 273 2) ;DIMALTU-sets the units for alt. units (cons 275 0) ;DIMAUNIT-sets the angular format for angular dims (cons 276 1); DIMFRAC (cons 277 2); DIMLUNIT ;2 decimale ; 4architettonico (cons 278 0); DIMDSEP (cons 279 Text_Movement); DIMTMOVE (cons 280 0) ;DIMJUST-controls the horizontal positioning of dim text (cons 281 -1); DIMSD1 (cons 282 -1); DIMSD2 (cons 283 1); DIMTOLJ (cons 284 3); DIMTZIN (cons 285 1); DIMALTZ (cons 286 0) ;DIMALTTZ-Toggles the suppression in tolerance values ;(cons 287 0); DIMFIT ;(cons 288 0); DIMUPT ;(cons 289 0); DIMATFIT (cons 340 (tblobjname "style" "Estilo_Cotas")); DIMTXSTY ;(cons 341 (cdr (assoc 330 (entget (tblobjname "block" "."))))); DIMLDRBLK ;(cons 342 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK must setvar dimblk 1st ;(cons 343 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK1 ;(cons 344 (cdr (assoc 330 (entget(tblobjname "block" "_Oblique"))))); DIMBLK2 ;(cons 371 -2); DIMLWD ;(cons 372 -2); DIMLWE ) )1 point
Here is a start, I have now jumped to points, what I will do is provide a code sample but will provide a Word.doc with the sub entities highlighted via VLAX-DUMP so you can see down the tree and add any "Components" settings that you may want to customise, I need to do this as point styles with say 8 components and around 6+ items = 48+ variables. Maybe even code in a tree pasting into Autocad DWG. One thing I have come across is using blocks in label styles a problem with rescaling meant changing 8 components. See below (defun getstyleinfo (count stname / stylname lp lay layname) ;Get the Style info and write out (setq x 0) (repeat count (setq style (vlax-get-property lls 'Item x)) ; count is number of styles start at 0 (setq stylname (vla-get-Name style)); is style name ;Get the Label Properties (setq lp (vlax-get-property style 'LabelProperties)) ;Get the Aecc Layer Properties (setq lay (vlax-get-property lp 'Layer)) ;Get the Name of the Layer (setq layname (vlax-get-property lay 'Value)) (write-line (strcat stname "," stylname "," layname) fo) (setq x (+ x 1)) ) ) (load "vercheck") (AH:vercheck) ;Get the Alignment Label Styles (setq als (vlax-get-property *AeccDoc* 'AlignmentLabelStyles)) ; Property values: ; CurveLabelStyles ; DesignSpeedLabelStyles ; GeometryPointLabelStyles ; LineLabelStyles ; MajorStationLabelStyles ; MinorStationLabelStyles ; SpiralLabelStyles ; StationEquationLabelStyles ; StationOffsetLabelStyles ; TangentIntersectionLabelStyles (setq fo (open "c:\\temp\\aligns2.lst" "W")) ;Get the Line Label Styles (setq stname "CurveLabelStyles") (setq lls (vlax-get-property als 'CurveLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "DesignSpeedLabelStyles") (setq lls (vlax-get-property als 'DesignSpeedLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "GeometryPointLabelStyles") (setq lls (vlax-get-property als 'GeometryPointLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "LineLabelStyles") (setq lls (vlax-get-property als 'LineLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "MajorStationLabelStyles") (setq lls (vlax-get-property als 'MajorStationLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "CurveLabelStyles") (setq lls (vlax-get-property als 'CurveLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "MinorStationLabelStyles") (setq lls (vlax-get-property als 'MinorStationLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "SpiralLabelStyles") (setq lls (vlax-get-property als 'SpiralLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "StationEquationLabelStyles") (setq lls (vlax-get-property als 'StationEquationLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (setq stname "TangentIntersectionLabelStyles") (setq lls (vlax-get-property als 'TangentIntersectionLabelStyles)) (setq count (vla-get-count lls)) ; is how many style names (getstyleinfo count stname) (close fo) (princ) img-218115827-0001.pdf1 point
