Leaderboard
Popular Content
Showing content with the highest reputation on 04/30/2023 in all areas
  1. ; offset increment numbering with change direction - 2023.04.28 exceeds (vl-load-com) (defun c:WCOPY ( / ss util en ent alignpt obj originalnum basept ang deg dist rotateold rotateinput rotatememory newnewobj ss2 en2 ent2 alignpt2 counter) (sssetfirst nil) (setvar "cmdecho" 0) (setq counter 0) ;error control (defun *error* ( msg ) (if (>= counter 1) (progn (setq alignpt2 (cdr (assoc 11 (entget (entlast))))) (if (= alignpt alignpt2) (progn (vla-delete newnewobj) (princ "\n Temporary Object Deleted.") ) ) );end of progn );end of if (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\n Error: " msg)) ) (setvar 'cmdecho 1) (princ) ) (setq util (vla-get-utility (vla-get-activedocument (vlax-get-acad-object)))) (setq ss (ssadd)) (princ "\n Select Original Number (Text) : ") (if (setq ss (ssget '((0 . "TEXT")))) (if (= (sslength ss) 1) (progn (setq en (ssname ss 0)) (setq ent (entget en)) (setq alignpt (cdr (assoc 11 ent))) (setq obj (vlax-ename->vla-object en)) (setq originalnum (atoi (vl-princ-to-string (vlax-get-property obj 'TextString)))) (setq basept (getpoint "\n Pick Base Point : ")) (setq ang (angle basept alignpt)) (setq deg (* 180.0 (/ ang pi))) (setq dist (distance basept alignpt)) (cond ((or (<= 315 deg) (< deg 45)) (setq rotateold "D") (princ "\n Direction : Right") ) ((and (<= 45 deg) (< deg 135)) (setq rotateold "W") (princ "\n Direction : Up") ) ((and (<= 135 deg) (< deg 225)) (setq rotateold "A") (princ "\n Direction : Left") ) ((and (<= 225 deg) (< deg 315)) (setq rotateold "S") (princ "\n Direction : Down") ) ) (command "_tjust" ss "" "mc") (while (= 1 1) (setq rotateinput (strcase (getstring "\n Change Direction? Up(W), Down(S), Left(A), Right(D), Keep Previous Direction(SpaceBar)"))) (if (= rotateinput "") (if (= rotatememory "") (progn (setq rotateinput rotateold) ) (progn (setq rotateinput rotatememory) ) ) (progn) ) (princ "\n Direction : ") (princ rotateinput) (cond ((= rotateinput "W") (princ "Up(W) Selected.") (cond ((= rotateold "D") (setq newdeg (+ deg 90)) ) ((= rotateold "W") (setq newdeg deg) ) ((= rotateold "A") (setq newdeg (- deg 90)) ) ((= rotateold "S") (setq newdeg (+ deg 180)) ) (t (setq newdeg deg) ) ) ) ((= rotateinput "A") (princ "Left(A) Selected.") (cond ((= rotateold "D") (setq newdeg (+ deg 180)) ) ((= rotateold "W") (setq newdeg (+ deg 90)) ) ((= rotateold "A") (setq newdeg deg) ) ((= rotateold "S") (setq newdeg (- deg 90)) ) (t (setq newdeg deg) ) ) ) ((= rotateinput "S") (princ "Down(S) Selected.") (cond ((= rotateold "D") (setq newdeg (- deg 90)) ) ((= rotateold "W") (setq newdeg (+ deg 180)) ) ((= rotateold "A") (setq newdeg (+ deg 90)) ) ((= rotateold "S") (setq newdeg deg) ) (t (setq newdeg deg) ) ) ) ((= rotateinput "D") (princ "Right(D) Selected.") (cond ((= rotateold "D") (setq newdeg deg) ) ((= rotateold "W") (setq newdeg (- deg 90)) ) ((= rotateold "A") (setq newdeg (+ deg 180)) ) ((= rotateold "S") (setq newdeg (+ deg 90)) ) (t (setq newdeg deg) ) ) ) (t (setq newdeg deg) ) ) (setq ang (* pi (/ (+ newdeg 180) 180))) ;(princ ang) (setq basept (polar alignpt ang dist)) ;(princ basept) (setq newnewobj (vla-copy obj)) (setq counter (+ counter 1)) (setq ss2 nil) (setq ss2 (ssadd)) (setq en2 (vlax-vla-object->ename newnewobj)) (ssadd en2 ss2) (vlax-put-property newnewobj 'TextString (+ originalnum 1)) (setq ent2 (entget en2)) (command "_move" ss2 "" basept pause) ;(command "_pasteclip" pause) (setq originalnum (+ originalnum 1)) (setq rotatememory rotateinput) );end of while ) (progn (princ "\n Select 1 Text Only.") (c:WCOPY) ) ) ) (setvar "cmdecho" 1) (princ) ) Long time no see. this uses command instead of grread. because I want to be able to see the preview & using osnap. Move Command is easy way for me. Command : WCOPY 1. Select 1 Text (Number) 2. Pick Base Point 3. lisp check your Direction 4. Select Direction - Press W/A/S/D or SpaceBar 5. Pick Target Point
    1 point
  2. The size of the table is dependent upon the text height configured for a data row in your current Table Style; as such, if you were to configure your Table Style accordingly, you can avoid the additional scaling step.
    1 point
  3. Instead of this : (vl-cmdf "_.SCALE" (entlast) "" "_non" (trans pt 1 0) 0.1 "") try it with this : (vl-cmdf "_.SCALE" (entlast) "" "_non" (trans pt 1 0) 0.1)
    1 point
