Leaderboard
  1. Lee Mac
    Lee Mac
    Trusted Member
    • Points
      1
    • Posts
      21,009
  2. ReMark
    ReMark
    Trusted Member
    • Points
      1
    • Posts
      46,268
  3. BIGAL
    BIGAL
    Trusted Member
    • Points
      1
    • Posts
      19,652
  4. Dana W
    Dana W
    Trusted Member
    • Points
      1
    • Posts
      5,158
Popular Content
Showing content with the highest reputation on 04/05/2022 in all areas
  1. try setting TRIMEXTENDMODE to 1. That sets the trim default to immediately trim the selected object back to the nearest intersecting object if only one, or to the two nearest intersecting objects if two or more objects cross the selected object. I think that one came to be in 2018 didn't it? Not sure. I know it surprised me a few releases ago when I tried to select an object to trim and it just freakin' trimmed itself. The releases all started to run together for me more as my retirement day got closer, and as I started to run out of 'youknowhats" to give.
    1 point
  2. What does the following return for you at the AutoCAD command line?: (vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList") If the above returns a semi-colon instead of a comma, try replacing the commas in your CSV file with semi-colons. Alternatively, if you want to continue using a comma in your CSV files, replace line 300 of my program with: (setq sep ",")
    1 point
  3. You have to go on the manufactures web site and often values are not there, like max steer angle, can normally get wheel base info. Even these can be modelled.
    1 point
  4. I wouldn't know an ActiveX property if I tripped over one! LoL
    1 point
