Leaderboard
  1. rkmcswain
    rkmcswain
    Moderator
    • Points
      2
    • Posts
      3,007
  2. ronjonp
    ronjonp
    Trusted Member
    • Points
      1
    • Posts
      2,522
  3. hanhphuc
    hanhphuc
    Trusted Member
    • Points
      1
    • Posts
      1,069
  4. CADTutor
    CADTutor
    Administrator
    • Points
      1
    • Posts
      1,462
Popular Content
Showing content with the highest reputation on 11/02/2018 in all areas
  1. I was refering to the lisp code, not "excel" The lisp codes would be exactly the same for the two lisps bar one would divide or multiply the length returned in this line leng (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline)) This would be either leng (* (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline)) 1000) OR leng (/ (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline)) 1000)
    1 point
  2. The vast majority of the feedback I've received about the new forum software has been positive and I'm very grateful to everyone who flagged up issues and contributed to making the migration a success. Now that the dust has settled, it's a good time to hone your skills. There is way more to the Invision Community interface than it initially appears, so I thought you might like a link to this blog post from the developers. I'm sure you'll find something useful here that will make your forum interactions even better. 5 Secret Interface Tips If you have a top tip for using this forum, just add it to this thread.
    1 point
  3. Maybe you could use THIS in conjunction with THIS? Better yet, use Elepanov's Triangulate code to generate the network between the blocks then use the the Dijkstra code.
    1 point
  4. The topic approval speed is very fast now. Thanks!
    1 point
  5. BricsCAD unplugged, from the conference, with Heidi Hewett, Erik de Keyser, and Rick Allen
    1 point
  6. In fact my intention was simple, in order to clean up the [BBcodes] within the new code tags in this forum. Therefore, IMO optimized with CLIPBOARD without using 'getfiled' is much more convenient, isn't it? code updated - post#1 Copy text (from forum) -> run 'FORUM' (in ACAD) -> [Ctrl+V] Paste (in forum active editor) Done!
    1 point
