; simple table to excel ; expects Title header and data ; BY Alanh Jan 2022 ; do not have excel open (defun c:tab2excel ( / x y z AH:putcell Ah:opennew number2alpha obj cols row) (defun AH:putcell (cellname val1 / ) (setq myRange (vlax-get-property (vlax-get-property myxl "ActiveSheet") "Range" cellname)) (vlax-put-property myRange 'Value2 val1) ) (defun AH:opennew ( / ) (if (= (setq myxl (vlax-get-object "Excel.Application") ) nil) (setq myxl (vlax-get-or-create-object "excel.Application")) ) (vla-put-visible myXL :vlax-true) (vlax-put-property myxl 'ScreenUpdating :vlax-true) (vlax-put-property myXL 'DisplayAlerts :vlax-true) ) ; Number2Alpha - Converts Number into Alpha string ; Function By: Gilles Chanteau from Marseille, France ; Arguments: 1 ; Num# = Number to convert ; Syntax example: (Number2Alpha 731) = "ABC" ;------------------------------------------------------------------------------- (defun Number2Alpha (Num# / Val#) (if (< Num# 27) (chr (+ 64 Num#)) (if (= 0 (setq Val# (rem Num# 26))) (strcat (Number2Alpha (1- (/ Num# 26))) "Z") (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#))) ) ) );defun Number2Alpha (AH:opennew) (vlax-invoke-method (vlax-get-property myXL 'WorkBooks) 'Add) (setq obj (vlax-ename->vla-object (car (entsel "Pick table ")))) (setq cols (vla-get-columns obj)) (setq rows (vla-get-rows obj)) (alert (strcat (rtos rows 2 0) " rows " (rtos cols 2 0) " columns \n will now send to excel ")) (AH:putcell "A1" (vla-getText Obj 0 0 )) (setq x 1 y 1 z 2) (repeat cols (AH:putcell (strcat (Number2Alpha x) (rtos z 2 0)) (vla-getText Obj y (- x 1) )) (setq x (1+ x)) ) (setq y 3) (repeat (- rows 2) (setq x 1 ) (repeat cols (AH:putcell (strcat (Number2Alpha x) (rtos y 2 0)) (vla-getText Obj y (- x 1) )) (setq x (1+ x)) (princ (strcat "\nRow " (rtos y 2 0))) ) (setq y (1+ y)) ) (vlax-release-object myXL) (alert "Please save the excel and close if you want to import another table ") (princ) ) (c:tab2excel)
