;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; ;;; ;;; Align To Direction ;;; ;;; Created by Jonathan Handojo ;;; ;;; ;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; ;;; ;;; This routine allows users to align any objects to a certain direction that contains any ;;; ;;; one of the following properties: ;;; ;;; ;;; ;;; 1. Insertion Point ;;; ;;; 2. Text Position ;;; ;;; 3. Text Alignment Position ;;; ;;; ;;; ;;; Upon issuing the command ATD, the user will be prompted a selection of objects without any ;;; ;;; filters. This will then be filtered after the selection set, highlighting the list of ;;; ;;; objects to be aligned. The user will be prompted the direction by clicking two point, or ;;; ;;; one of the following options: ;;; ;;; ;;; ;;; 1. X-direction, ;;; ;;; 2. Y-direction (relative to the UCS) ;;; ;;; 3. "PerpendicularToCurve" - the user clicks a point on any curve objects and the ;;; ;;; direction will be perpendicular to the curve at that specified point. ;;; ;;; 4. "AlongCurve" - similar to step 3, but as opposed to perpendicular, it will be the ;;; ;;; direction of the curve at that specified point. ;;; ;;; ;;; ;;; Curve Selection is compatible with all curves within complex objects, regardless of depth. ;;; ;;; Several examples include curves found in nested blocks, xrefs, tables, dimensions, etc. ;;; ;;; ;;; ;;; ;;; ;;; Following this step, the user can choose to specify an optional distance that would like ;;; ;;; to be used as an "offset". Exactly taking up the feature from the built-in AutoCAD ;;; ;;; "OFFSET" command, this prompt offers the "Through" option in which the user then drags the ;;; ;;; mouse and click on a point to specify the location. If the user has chosed to specify a ;;; ;;; distance, the user will then be prompted to specify a point from which the offset will be ;;; ;;; calculated from. ;;; ;;; ;;; ;;; The user can next specify the point where all the objects will be aligned to that ;;; ;;; direction. Simply put, it's like aligning marbles on a table using a ruler. Except unlike ;;; ;;; marbles, AutoCAD entities do not keep rolling and stick to your cursor. Should the user ;;; ;;; have specified zero distance, the program will align all the objects along that point and ;;; ;;; the command will immediately terminate. Should the user have specified a positive distance, ;;; ;;; the user can then specify a point denoting the side to place the objects. ;;; ;;; ;;; ;;; Objects that I have successfully worked with this program include: ;;; ;;; ;;; ;;; 1. Tables ;;; ;;; 2. Dimensions ;;; ;;; 3. Blocks ;;; ;;; 4. OLE Images ;;; ;;; 5. Texts and MTexts (regardless of justification) ;;; ;;; ;;; ;;; This program will work under any UCS. ;;; ;;; ;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;; ;;; ;;; Versions and updates ;;; ;;; ------------------------------------------------------------ ;;; ;;; ;;; ;;; Version 1.0 - First release (27/04/20) ;;; ;;; ;;; ;;; Version 1.1 (23/11/2020) - Included "Perpendicular to Curve" and "Along Curve" option. ;;; ;;; ;;; ;;; Version 1.2 (06/10/2021) - Curve selection enhanced compatibility with nested complex ;;; ;;; objects and blocks. ;;; ;;; ;;; ;;; Version 1.2 (05/05/2023) - Command to now work regardless of elevation of objects on any ;;; ;;; plane. ;;; ;;; - Included a feature to align objects at a specified distance ;;; ;;; from a point. ;;; ;;; ;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun c:atd (/ *error* acadobj activeundo adoc alpts ang ang1 ang2 blk gr grp grv halfpi movpt msg msp p1 p2 p3 pg pt snp snpang ss sse x y ) (defun *error* ( msg ) (setvar 'snapang snp) (if sse (mapcar '(lambda (x) (redraw x 4)) sse)) (vla-EndUndoMark adoc) (if (not (wcmatch (strcase msg T) "*break*,*cancel*,*exit*")) (princ (strcat "Error: " msg)) ) ) (defun _inters (ll ur p1 p2) (vl-some (function (lambda (a b) (inters a b p1 p2) ) ) (list ll (list (car ur) (cadr ll)) ur (list (car ll) (cadr ur))) (list (list (car ur) (cadr ll)) ur (list (car ll) (cadr ur)) ll) ) ) (setq acadobj (vlax-get-acad-object) adoc (vla-get-ActiveDocument acadobj) blk (vla-get-blocks adoc) msp (vla-get-ModelSpace adoc) activeundo nil ) (if (= 0 (logand 8 (getvar "UNDOCTL"))) (vla-StartUndoMark adoc) (setq activeundo T)) (setq snp (getvar 'snapang)) (if (setq ss (vl-remove-if-not '(lambda (x) (and (vlax-write-enabled-p x) (or (vlax-property-available-p x 'insertionpoint) (and (eq (strcase (vla-get-ObjectName x)) "ACDBBLOCKREFERENCE") (eq (vla-get-IsXRef (vla-item blk (vla-get-EffectiveName x))) :vlax-false) ) (vlax-property-available-p x 'textposition) (vlax-property-available-p x 'textalignmentpoint) (vlax-property-available-p x 'center) ) ) ) (atd:selset-to-list-vla (ssget "_:L")) ) ) (progn (setq sse (mapcar 'vlax-vla-object->ename ss)) (mapcar '(lambda (x) (redraw x 3)) sse) (setq ang (progn (initget 1 "X Y PErpendicularToCurve ALongCurve") (getangle "\nSpecify alignment direction [X/Y/PErpendicularToCurve/ALongCurve]: ")) ang (+ (setq halfpi (* 0.5 pi)) (cond ( (numberp ang) ang) ( (eq ang "X") 0) ( (eq ang "Y") halfpi) ( (wcmatch ang "PErpendicularToCurve,ALongCurve") (+ (atd:GetDirectionAtCurve "\nSpecify point at any curve: ") (if (eq ang "PErpendicularToCurve") halfpi 0) ) ) ) ) p1 (trans (vlax-get (car ss) (atd:objprop (car ss))) 0 1) p2 (polar p1 ang 1) alpts (mapcar '(lambda (x / p3) (list x (atd:objprop x) ( (lambda (y) (list (car y) (cadr y) (caddr p3)) ) (inters (atd:3p->2p p1) (atd:3p->2p p2) (atd:3p->2p (setq p3 (trans (vlax-get x (atd:objprop x)) 0 1))) (atd:3p->2p (polar p3 (+ halfpi ang) 1)) nil ) ) ) ) ss ) ) (initget "Through") (setq |ATD_Distance (cond ( (getdist (strcat "\nSpecify alignment distance or [Through] <" (if (numberp |ATD_Distance) (rtos |ATD_Distance 2 3) "Through") ">: " ) ) ) ( |ATD_Distance ) ) ) (if (numberp |ATD_Distance) (setq pt (getpoint "\nSpecify base point : ")) ) (setvar 'snapang ang) (princ (setq msg "\nSpecify alignment point or [Distance] : ")) (while (progn (setq gr (grread T 15 0) grp (last gr) grv (car gr) ) (cond ( (member grv '(5 3)) (if (and (numberp |ATD_Distance) (atd:Point-p pt)) (if (not (apply 'LM:Clockwise-p (mapcar 'atd:3p->2p (list pt (polar pt ang 100) grp)))) (setq movpt (inters (atd:3p->2p (setq pg (polar pt (+ ang halfpi) |ATD_Distance))) (atd:3p->2p (polar pg ang 10)) (atd:3p->2p p1) (atd:3p->2p (polar p1 (- ang halfpi) 10)) nil ) ) (setq movpt (inters (atd:3p->2p (setq pg (polar pt (- ang halfpi) |ATD_Distance))) (atd:3p->2p (polar pg ang 10)) (atd:3p->2p p1) (atd:3p->2p (polar p1 (- ang halfpi) 10)) nil ) ) ) (setq movpt (inters (atd:3p->2p grp) (atd:3p->2p (polar grp ang 10)) (atd:3p->2p p1) (atd:3p->2p (polar p1 (- ang halfpi) 10)) nil ) ) ) (setq movpt (list (car movpt) (cadr movpt) (caddr p1))) (mapcar '(lambda (x) (vlax-put (car x) (cadr x) (trans (mapcar '+ (last x) (mapcar '- movpt p1)) 1 0)) ) alpts ) (mapcar '(lambda (x) (redraw x 3)) sse) (if (and (numberp |ATD_Distance) (atd:Point-p pt)) (not (or (equal |ATD_Distance 0.0 1e-7) (= grv 3) ) ) (= grv 5) ) ) ( (= grv 2) (cond ( (member grp '(68 100)) ; Keyboard D (initget "Through") (setq |ATD_Distance (cond ( (getdist (strcat "\nSpecify alignment distance or [Through] <" (if (numberp |ATD_Distance) (rtos |ATD_Distance 2 3) "Through") ">: " ) ) ) ( |ATD_Distance ) ) ) (if (numberp |ATD_Distance) (setq pt (getpoint "\nSpecify base point : ")) ) (princ msg) ) ( (member grp '(80 112)) ; Keyboard P nil ) ( T ) ) ) ( (= grv 25) nil) ( T ) ) ) ) ) ) (mapcar '(lambda (x) (redraw x 4)) sse) (setvar 'snapang snp) (if activeundo nil (vla-EndUndoMark adoc)) (princ) ) (defun atd:Point-p (arg) (and (eq (type arg) 'variant) (eq (type (setq arg (vlax-variant-value arg))) 'safearray) (setq arg (vlax-safearray->list arg)) ) (and (listp arg) (listp (cdr arg)) (<= 2 (length arg) 3) (vl-every 'numberp arg) ) ) (defun atd:3p->2p (pt) (list (car pt) (cadr pt)) ) (defun atd:objprop (obj) (cond ( (vlax-property-available-p obj 'insertionpoint) (if (and (vlax-property-available-p obj 'textalignmentpoint) (null (equal (vlax-get obj 'textalignmentpoint) '(0 0 0) 1e-8)) ) 'textalignmentpoint 'insertionpoint ) ) ( (vlax-property-available-p obj 'textalignmentpoint) 'textalignmentpoint) ( (vlax-property-available-p obj 'textposition) 'textposition) ( (vlax-property-available-p obj 'center) 'center) ) ) (defun atd:GetDirectionAtCurve (msg / crv det mtx pt vec) (while (progn (setvar "errno" 0) (initget "Exit") (setq det (nentselp (getpoint msg))) (cond ( (= (getvar "errno") 7) (princ "\nNothing selected.")) ( (member det '("Exit" nil)) nil) ( (not (wcmatch (cdr (assoc 0 (entget (setq crv (car det))))) "LINE,LWPOLYLINE,ARC,ELLIPSE,CIRCLE,SPLINE")) (princ "\nNo curves detected") ) ( t (if (setq pt (trans (cadr det) 1 0) mtx (caddr det)) (setq mtx (atd:4x4->3x3 mtx) vec (trans (mxv (car mtx) (vlax-curve-getfirstderiv crv (vlax-curve-getparamatpoint crv (vlax-curve-getclosestpointto crv (mxv (gc:Inv3x3 (car mtx)) (mapcar '- pt (cadr mtx))) ) ) ) ) 0 1 t ) ) (setq vec (trans (vlax-curve-getfirstderiv crv (vlax-curve-getparamatpoint crv (vlax-curve-getclosestpointto crv pt))) 0 1 t)) ) nil ) ) ) ) (if vec (angle '(0.0 0.0 0.0) vec)) ) (defun atd:selset-to-list-vla (ss / rtn) (if ss (repeat (setq i (sslength ss)) (setq i (1- i) rtn (cons (vlax-ename->vla-object (ssname ss i)) rtn)) ) ) ) (defun atd:4x4->3x3 (mx) (list (mapcar '(lambda (a) (reverse (cdr (reverse a))) ) (reverse (cdr (reverse mx))) ) (mapcar 'last mx) ) ) (defun atd:GetCorner (/ ctr rt ss vs zm) ;; in DCS (setq ctr (trans (getvar 'viewctr) 1 2) vs (getvar 'viewsize) ss (getvar 'screensize) rt (/ vs (cadr ss)) zm (mapcar '(lambda (a) (abs (* 0.5 rt a))) (append ss '(0.0))) ) (list (mapcar '- ctr zm) (mapcar '+ ctr zm) ) ) ;; gc:Inv3x3 ;; Return the inverse transformation matrix (3X3) ;; ;; Argument ;; mat: a 3x3 matrix (defun gc:Inv3x3 (mat / a b c d e f g h i det) (mapcar 'set '(a b c d e f g h i) (mapcar 'float (apply 'append mat)) ) (setq det (+ (* a e i) (* b f g) (* c d h) (- (* c e g)) (- (* b d i)) (- (* a f h)) ) ) (if (and (/= 0 det) (setq det (/ 1 det))) (mapcar '(lambda (v) (mapcar '(lambda (x) (* x det)) v) ) (list (list (- (* e i) (* f h)) (- (* c h) (* b i)) (- (* b f) (* c e)) ) (list (- (* f g) (* d i)) (- (* a i) (* c g)) (- (* c d) (* a f)) ) (list (- (* d h) (* e g)) (- (* b g) (* a h)) (- (* a e) (* b d)) ) ) ) ) ) ;; Matrix x Vector - Vladimir Nesterovsky ;; Args: m - nxn matrix, v - vector in R^n (defun mxv ( m v ) (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m) ) ;; Clockwise-p - Lee Mac ;; Returns T if p1,p2,p3 are clockwise oriented (defun LM:Clockwise-p ( p1 p2 p3 ) (< (* (- (car p2) (car p1)) (- (cadr p3) (cadr p1))) (* (- (cadr p2) (cadr p1)) (- (car p3) (car p1))) ) )
