1 Screenshot
About This File
TotalBoundary (Pro) is a professional plugin for generating 2D outline drawings of various degrees of complexity with AutoCAD®. The outline drawings it creates are closed polylines marking the boundaries of various types of objects, which can include elementary entities (lines and arcs) as well as complex blocks and curves (ellipses and splines).
What sets the TotalBoundary (Pro) utility apart from AutoCAD's built-in tools (such as BOUNDARY, BPOLY) and from other third-party programs is its high productivity and stability, and also the quality of the outlines it generates. The inbuilt algorithm for detecting spacing (gaps) between neighboring objects allows users to create enclosed outline polylines with exceptional accuracy. The program can process tens of thousands of objects extremely efficiently (in a matter of seconds), flawlessly generating highly complex outline polylines in the selected drawings.
Key features:
  • The program's powerful engine allows it to build enclosed polylines rapidly along the perimeter of selected drawing fragments.
  • The original drawing needs no advance preparation (removing superfluous unconnected lines, creating an additional enclosed boundary polyline around the original drawing fragment).
  • When the program creates an outline, it automatically identifies and removes gaps in places where primitives meet. The maximum size of these gaps can be set directly by the user.
  • The program replaces splines and ellipses used in defining an outline with true polylines created by means of piecewise linear approximation.
  • The user can also easily set the thickness and color of the polylines the program generates, if required.
  • The program offers an automatic filling (solid hatching) option for the outlines it generates.
What's New in Version 4.2.28.0   See changelog
Released
Added support AutoCAD 2025
  • Like 3
User Feedback
  • This will not be shown to other users.
  • Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
    Add a review...
Jesús Manuel Gutiérrez Mor
Muy bueno y bastante rápido y útil para gestionar contenidos cerrados y ámbito de perímetros de aplicación. Para luego extraer dimensiones y de elementos que componen el espacio de trabajo y desarrollo de dibujo
Adi Aviram
Hello,
I am looking for plug-in that will be able to read a batch of multi 2D DWG format drawings of extruded profiles , and export automatically , only the shapes of the close contour profile in polyline type , with all the dimensions to DXF format files (  tables , templates, other texts ...will not be in the exported DXF format files) . if the drawing have a detailed views , the dimensions of  the details views will move to the main profile shape)
In case that this interesting you, I will accept to get an offer to pay for this.
Thank you Adi Aviram.
John Watson
This app greatly saves my time! I often have to draw complex outlines of various rooms.
cybermen
   1 of 1 member found this review helpful 1 / 1 member
I use it in factory layout, is a very useful CAD plugin.
  • Like 2
