; Getvals multi allows multiple line inputs ; By Alan H Feb 2019 ; code examples ; the input box size can be bigger just change the two values tetsed with 145 145 and worked ok. ; (if (not AH:getvalsm)(load "Multi Getvals.lsp")) ; (setq ans (AH:getvalsm (list "This is heading" "Line 1" 5 4 "11" "Line2" 8 7 "22" "Line3" 8 7 "33" "Line4" 8 7 "4"))) ; ; (setq newvals (AH:getvalsm (list "Cross fall percent" "Enter Horizontal scale " 5 4 "100" "Enter Vertical scale" 5 4 "50" "Enter number of decimal places" 5 4 "2"))) ; note the values are strings (defun AH:getvalsm (dcllst / x y num fo fname keynum key_lst v_lst) (setq num (/ (- (length dcllst) 1) 4)) (setq x 0) (setq y 0) (setq fo (open (setq fname (vl-filename-mktemp "" "" ".dcl")) "w")) (write-line "ddgetvalAH : dialog {" fo) (write-line (strcat " label =" (chr 34) (nth 0 dcllst) (chr 34) " ;") fo) (write-line " : column {" fo) (repeat num (write-line "spacer_1 ;" fo) (write-line ": edit_box {" fo) (setq keynum (strcat "key" (rtos (setq y (+ Y 1)) 2 0))) (write-line (strcat " key = " (chr 34) keynum (chr 34) ";") fo) (write-line (strcat " label = " (chr 34) (nth (+ x 1) dcllst) (chr 34) ";") fo) (write-line (strcat " edit_width = " (rtos (nth (+ x 2) dcllst) 2 0) ";") fo) (write-line (strcat " edit_limit = " (rtos (nth (+ x 3) dcllst) 2 0) ";") fo) (write-line " is_enabled = true ;" fo) (write-line " }" fo) (setq x (+ x 4)) ) (write-line " }" fo) (write-line "spacer_1 ;" fo) (write-line "ok_only;}" fo) (close fo) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "ddgetvalAH" dcl_id)) (exit) ) (setq x 0) (setq y 0) (setq v_lst '()) (repeat num (setq keynum (strcat "key" (rtos (setq y (+ Y 1)) 2 0))) (setq key_lst (cons keynum key_lst)) (set_tile keynum (nth (setq x (+ x 4)) dcllst)) (mode_tile keynum 3) ) (action_tile "accept" "(mapcar '(lambda (x) (setq v_lst (cons (get_tile x) v_lst))) key_lst)(done_dialog)") (start_dialog) (unload_dialog dcl_id) (vl-file-delete fname) (princ v_lst) )
