bonehead_96 Posted May 7 Share Posted May 7 Need Help please!! I am getting an error message "error: no function definition: ACET-SS-DRAG-MOVE" using the attached Lisp after installing AutoCad 2025. I have used this lisp in previous version with no issues. It's probably something simple, but I can't find it. MatBubb1.lsp HMatbub.dwg Quote Link to comment Share on other sites More sharing options...
Steven P Posted May 7 Share Posted May 7 Looks like an exress tool - did you install them as well with 2025? Quote Link to comment Share on other sites More sharing options...
bonehead_96 Posted May 7 Author Share Posted May 7 Thanks for looking Yes, express tools is loaded I think I have found the problem. for some reason "acetutil.arx " is/was not loaded. I added it to load in the startup suite and the lisp is working. Is there a reason you can think of that "acetutil.arx" would have not been loaded? Quote Link to comment Share on other sites More sharing options...
mhupp Posted May 8 Share Posted May 8 (edited) FYI (setq curosap (getvar "osmode")) (setq cudragmode (getvar "dragmode")) (setq olsnap (getvar "SNAPSTYL")) (setq oortho (getvar "orthomode")) (setq oattdia (getvar "attdia")) (setq oattreq (getvar "attreq")) (setq odimsc (getvar "dimscale")) (setvar "orthomode" 0) (setvar "osmode" 545) (setvar "cmdecho" 1) (setvar "snapstyl" 0) (setvar "dimscale" 1) (setvar "attdia" 1) (setvar "attreq" 1) .... (setvar "osmode" curosap) (setvar "dragmode" cudragmode) (setvar "snapstyl" olsnap) (setvar "orthomode" oortho) (setvar "dimscale" odimsc) (setvar "attdia" oattdia) (setvar "attreq" oattreq) Can be condensed down to the following (setq vars '(osmode dragmode snapstyl orthomode attdia attreq dimscale MENUECHO CMDECHO) ;list of variables you want to capture/set while in lisp vals (mapcar 'getvar vars) ;store old values in a list vals will look like the list below ) (mapcar 'setvar vars '(545 2 1 0 1 1 1 1 1)) ;set new values ... (mapcar 'setvar vars vals) ;restore old values Edited May 8 by mhupp Quote Link to comment Share on other sites More sharing options...
pkenewell Posted May 8 Share Posted May 8 14 hours ago, bonehead_96 said: Thanks for looking Yes, express tools is loaded I think I have found the problem. for some reason "acetutil.arx " is/was not loaded. I added it to load in the startup suite and the lisp is working. Is there a reason you can think of that "acetutil.arx" would have not been loaded? With AutoCAD 2025, they changed the Express tools to Demand loading, so if a ET function has not been run, then it won't be loaded. Here is a function I use to make sure it gets loaded: ;|============================================================================== Function Name: (pjk-ExpressToolsLoad) Arguments: None Returns: Nothing Description: This Subroutine Loads Express Tools if not loaded, and alerts the user if Express Tools is not installed. ================================================================================|; (defun pjk-ExpressToolsLoad () (if (not (acet-util-ver)) (if (findfile "acetutil.arx") (arxload "acetutil.arx" "\nError - AutoCAD Express Tools Utilities not loaded") (Alert (strcat "\nAutoCAD Express Tools is Needed for this Function.\nInstall the" "AutoCAD express tools from the original product install package." ) ) ) ) ) ;; End Function (pjk-ExpressToolsLoad) Quote Link to comment Share on other sites More sharing options...
bonehead_96 Posted May 8 Author Share Posted May 8 Thanks I guess the "On Demand Loading" works for some people, but it sure is a pain for some too. Thanks again 1 Quote Link to comment Share on other sites More sharing options...
Steven P Posted May 8 Share Posted May 8 I've just switched all my lisps over to on demand loading, it speeds things up on drawing opening. Biggest hassle is to add new LISPs to the on demand loading file, but once done it is no hassle. I'll probably end up with a 50-50 mix of on demand and pre-loading LISPs. I have a file with the following formated LISPs in, if this routine is called then it loads the relevant file, and then runs the LISP. If the LISP is loaded then usually is is loaded after this file and will run as normal without going through the load (latest loading of the LISP is the one that runs) (defun c:3PARC ( / ) (load "C:\\Users\\SP\\Desktop\\AutoCAD\\AutoCAD LISPS\\LinesToArc.lsp") (c:3PARC) (princ) ;;LISP File / Run LISP ) Could be modified to: (defun acet-ss-drag-move ( ss pt Prompt1 Prompt2 / ) (if (findfile "acetutil.arx") (progn (arxload "acetutil.arx" "\nError - AutoCAD Express Tools Utilities not loaded") (acet-ss-drag-move ss pt Prompt1 Prompt2) ) (Alert "\nAutoCAD Express Tools is Needed for this Function.\nInstall the AutoCAD express tools from the original product install package.") ) (princ) ) Have this file load on start up 1 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 9 Share Posted May 9 Do you use Autoload function ? (autoload "COPY0" '("COPY0")) (autoload "COPYCOMMAND" '("ZZZ")) (autoload "COVER" '("COVER")) (autoload "DIMFLIP" '("DIMFLIP")) (autoload "DRAWXFALL" '("DRAWXFALL")) 1 Quote Link to comment Share on other sites More sharing options...
bonehead_96 Posted Wednesday at 03:25 PM Author Share Posted Wednesday at 03:25 PM Thanks for all the input and sorry for the late response. We had some bad weather here and have been out of touch for a while Quote Link to comment Share on other sites More sharing options...
