Move to new layer with suffix
Chmcdan211
All,
I would like to know if anyone knows of a lisp that will do this.
1. Copy the layer of a selected object (4"-HG-BC38-9100)
2. Add a suffix to the end of that layer (-UG)
3. Move only the selected object to that new layer (4"-HG-BC38-9100-UG)
I have made a lisp that will add a suffix to the selected layer, however I can't figure out how to keep all other objects on the original layer and move the selected object to a layer of the same name with a suffix.
EX. objects are created on layer 4"-HG-BC38-9100
I want the lisp and select an object that is on that layer and have the lisp copy that layer, add a -UG suffix to it and move only the selected object to layer 4"-HG-BC38-9100-UG
I think that makes sense...
Chris
There are different ways to do it, but using simple lisp
; simple version
(defun C:test ( / obj layname suff)
(setq obj (entsel))
(setq layname (cdr (assoc 8 (entget (car obj)))))
(setq suff (getstring " Enter suffix"))
(setq layname (strcat layname suff))
(command "-layer" "N" layname "")
(command "CHPROP" obj "" "LA" layname "")
(c:TEST)
  • 4 years later...
; simple version
(setq obj (entsel))
(c:TEST)
Can this be made to work for a selection of multiple objects of different layers? Currently it only works for single object selection.
Edit: It would be much helpful if the newly created layer (with the suffix) keeps the properties of the original layer (Color, line W and type...). As it is now it resets the layer properties.
Edited by enthralled
Retain layer properties
The simple version above uses the layer of the selected object as the base for the new layer. How would this work if you are selecting multiple objects on multiple layers?
  • 2 weeks later...
Try one of these 2 functions. The 1st one (TEST2) just renames the layers. The 2nd one (TEST3) creates new layers and moves the selection to the new layers (Note - Currently the color and linetypes  of the original layers are not replicated in TEST3).
(defun C:test2 ( / cnt el la llst nlst ss suff)
   (setq ss (ssget) cnt 0)
   (repeat (sslength ss)
       (setq el (entget (ssname ss cnt))
             la (cdr (assoc 8 el))
             cnt (1+ cnt)
       (if (not (member la llst))(setq llst (cons la llst)))
   (if (setq suff (getstring "\nEnter suffix for layers: "))
         (setq nlst (mapcar '(lambda (x) (strcat x "-" suff)) llst) cnt 0)
         (foreach i llst
            (command "._-rename" "_LA" i (nth cnt nlst))
            (setq cnt (1+ cnt))
(defun C:test3 ( / cnt el en la llst nlst ss suff)
             cnt (1+ cnt)
         (foreach i nlst
            (command "._-layer" "_N" i "")
            (setq cnt (1+ cnt))
         (setq cnt 0)
             (setq en (ssname ss cnt)
                   el (entget en)
                   el (subst (cons 8 (strcat la "-" suff)) (assoc 8 el) el)
                   cnt (1+ cnt)
             (entmod el)
Edited by pkenewell
To preserve original layer properties, I'm currently cutting the objects to a new dwg, rename the layers with required suffix, then cut and paste back into the original drawing.
Try this revision to my TEST3 command. It currently only reads the ACI color codes from the original layers, but could be updated to capture the other color codes (truecolor, colorbook) as well. Let me know if that is necessary.
(defun C:test3 ( / cl cnt el en la llst lt nlst ol suff)
             cnt (1+ cnt)
         (foreach i nlst
            (setq ol (tblsearch "LAYER" (nth 1 llst))
                  cl (cdr (assoc 62 ol))
                  lt (cdr (assoc  6 ol))
            (command "._-layer" "_N" i "_c" cl i "_l" lt i "")
            (setq cnt (1+ cnt))
         (setq cnt 0)
                   el (entget en)
                   cnt (1+ cnt)
             (entmod el)
Edited by pkenewell
  • 4 years later...
             cnt (1+ cnt)
         (foreach i nlst
            (setq cnt (1+ cnt))
         (setq cnt 0)
                   el (entget en)
                   cnt (1+ cnt)
             (entmod el)
Hey,
Sorry for the late reply! The code provided was incredibly helpful for what I needed back then.
Now, I need it to retain all the original layer properties, including any color types, line weights, line types, and transparency settings, if possible.
Any input would be greatly appreciated!
Thanks
I got this far with the help of ai, it does what I need with the exception of inheriting parent layer Transparency:
;; Modified from pkenewell's lisp: https://www.cadtutor.net/forum/topic/56459-move-to-new-layer-with-suffix/#comment-556088
(defun C:cnl ( / ss cnt el en la llst lt nlst ol suff newLayerProps)
  (setq AcDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
  (vla-StartUndoMark AcDoc)
   (setq ss (ssget ":L") cnt 0)
             cnt (1+ cnt)
       (if (not (member la llst)) (setq llst (cons la llst)))
   (if (setq suff (getstring T "\nEnter suffix for new layers for selected objects: "))
         (setq nlst (mapcar '(lambda (x) (strcat x suff)) llst) cnt 0)
         (foreach i nlst
            (if (not (tblsearch "LAYER" i))
                  (setq ol (tblsearch "LAYER" (substr i 1 (- (strlen i) (strlen suff)))))
                  (if ol
                       (setq newLayerProps (entget (tblobjname "LAYER" (cdr (assoc 2 ol)))))
                       (setq newLayerProps (subst (cons 2 i) (assoc 2 newLayerProps) newLayerProps))
                       (entmakex newLayerProps)
            (setq cnt (1+ cnt))
         (setq cnt 0)
                   el (entget en)
                   el (subst (cons 8 (strcat la suff)) (assoc 8 el) el)
                   cnt (1+ cnt)
             (entmod el)
  (vla-EndUndoMark AcDoc)
@enthralled A little trickier with getting and setting transparency - but almost all can be done fairly easily with Visual LISP Activex functions.
;; New version by Pkenewell. Uses Visual LISP & ActiveX
;; Updated 5/8/2024 to check for existing layers already with new name.
(defun C:CNL ( / acdoc cnt el la llst lt lw lyrs np nl ss su tr)
   (vl-load-com)
         lyrs  (vla-get-layers acdoc)
   (if (and
         (setq ss (ssget ":L"))
         (/= (setq su (getstring T "\nEnter suffix for new layers for selected objects: ")) "")
         (repeat (setq cnt (sslength ss))
            (setq el (entget (ssname ss (setq cnt (1- cnt))))
         (foreach n llst
            (if (not (tblsearch "LAYER" (strcat n su)))
                  (setq ob  (vlax-ename->vla-object (setq el (tblobjname "LAYER" n)))
                        col (vla-get-truecolor  ob)
                        lt  (vla-get-linetype   ob)
                        lw  (vla-get-lineweight ob)
                        np  (vla-get-plottable  ob)
                        nl  (vla-add lyrs (strcat (vla-get-name ob) su))
                        tr  (getpropertyvalue el "Transparency")
                  (vla-put-truecolor  nl col)
                  (vla-put-linetype   nl lt)
                  (vla-put-lineweight nl lw)
                  (vla-put-plottable  nl np)
                  (setpropertyvalue (vlax-vla-object->ename nl) "Transparency" tr)
Edited by pkenewell
Edited to correct error in setting transparency.
  • Like 2
Here's another one I've had around for a while modified to get the transparency too. It's also good to exclude items that already contain the suffix so you don't end up with duplicate suffixes.
(defun c:layersuffix (/ a el f l nl s tm)
  ;; RJP » 2024-05-08
  (or (setq f (getenv "RJP_LayerSuffix")) (setq f (strcat "-" (getenv "username"))))
  (cond	((and (setq f (cond ((/= "" (setq tm (getstring (strcat "\nEnter suffix [<" f ">]: ")))) tm)
			    (f)
	      (setq s (ssget ":L" (list '(-4 . "<NOT") (cons 8 (strcat "*" f)) '(-4 . "NOT>"))))
	 (setenv "RJP_LayerSuffix" f)
	 (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (setq el
		  (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency"))
	   (or (tblobjname "layer" (setq nl (strcat l f)))
	       (entmakex (subst (cons 2 nl) (assoc 2 el) el))
	   (entmod (subst (cons 8 nl) (assoc 8 (entget e)) (entget e)))
Edited by ronjonp
  • Like 3
@pkenewell Thanks! Just to point out though, the updated lisp still doesn't take the transparency from the original layer 🤔
@ronjonp Works perfect. Thanks for sharing!
11 hours ago, ronjonp said:
(defun c: layersuffix (/ a el f l nl s tm)
@ronjonp A very convenient code. And can, please, for the prefix...
@enthralled I figured out the error - dumb little mistake; I had the wrong variable name when setting transparency to the original layer instead of the new one 😜 I have corrected my post above.
@ronjonp Nice code - does the job with DXF. I like how you filter out the possible new names on selection. HOWEVER, The new layer names could still exist and NOT be in the selection set. Still - good idea! I have updated my code above to filter out possible already existing new layers from the creation loop.
@Steven P While Lee's code is very creative, it is much shorter to use (getpropertyvalue) and (setpropertyvalue). It wasn't working for me due to a code typo, rather then the method.
Edited by pkenewell
I did wonder, never seen you post anything really that doesn't work. A second method is often good for other CAD packages, if one thing doesn't work then an older LISP might.
(Lees method might work well for one of mine that creates layers with dxf codes, but not checked that for yet, setproperty will also work well)
Edited by Steven P
  • Agree 1
@Nikon Here is a new version of my code that does either a prefix, suffix, or both:
;;  - Also updated for optional Prefix and/or Suffix.
;;  - Also added new created layer count.
(defun C:CNL ( / acdoc cnt el la llst lt lw lyrs np nl pr ss su tr)
   (vl-load-com)
   (if (and
         (setq pr (getstring T "\nEnter Prefix for new layers from selected objects <ENTER for None>: "))
         (setq su (getstring T "\nEnter suffix for new layers from selected objects <ENTER for None>: "))
         (not (= pr su ""))
         (setq cnt 0)
         (foreach n llst
            (if (not (tblsearch "LAYER" (strcat pr n su)))
                        nl  (vla-add lyrs (strcat pr (vla-get-name ob) su))
                  (if (tblsearch "LAYER" (strcat pr n su))(setq cnt (1+ cnt)))
         (if (> cnt 0)(princ (strcat "\n(" (itoa cnt) ") New Layers Created.")))
      (if (= pr su "")(princ "\nNo Suffix or Prefix Given - No new layers created."))
Edited by pkenewell
@pkenewell FWIW
;; This
(and (= pr "") (= su ""))
;; Could be this
(= "" pr su)
Also .. I realized that the transparency of a layer is stored as XDATA so:
;; Changing this
(setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e)))))))
;; To this gets all the layer properties including transparency 8-)
(setq el (entget (tblobjname "layer" (setq l (cdr (assoc 8 (entget e))))) '("AcCmTransparency")))
Code updated above.
3 hours ago, ronjonp said:
FWIW
@ronjonp Oh Yes - Thanks. I sometimes forget that you can put multiple terms in the "=" operator.
