ktbjx Posted December 12, 2018 Share Posted December 12, 2018 (defun c:roundingz (/ o s) (if (setq s (ssget ":L" '((0 . "*text")))) (foreach a (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object a)) (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 1)) ) ) (princ) ) (defun lm:roundto (n p) (lm:roundm n (expt 10.0 (- p)))) (defun lm:roundm (n m) (* m (atoi (rtos (/ n (float m)) 2 0)))) is it possible that numbers below 0.05 will retain the number, higher than that, will be changed into 1 decimal point?? because for example, 0.04 will give me 0.0... i need it to be the same 0.04 Quote Link to comment Share on other sites More sharing options...
1958 Posted December 12, 2018 Share Posted December 12, 2018 54 minutes ago, ktbjx said: 55 minutes ago, ktbjx said: (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 1)) (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 2)) Quote Link to comment Share on other sites More sharing options...
ktbjx Posted December 12, 2018 Author Share Posted December 12, 2018 1 hour ago, 1958 said: (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 2)) this makes the number into 2 decimals. the one i posted makes it into 1 decimal... so i was thinking if condition? but IDK how something like: if the value is <= 0.05 (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 2)) else (vla-put-textstring o (rtos (lm:roundto (atof (vla-get-textstring o)) 2) 2 1)) Quote Link to comment Share on other sites More sharing options...
1958 Posted December 12, 2018 Share Posted December 12, 2018 (defun c:roundingz (/ o s aa) (if (setq s (ssget ":L" '((0 . "*text")))) (foreach a (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object a) aa (lm:roundto (atof (vla-get-textstring o)) 2) ) (if (<= aa 0.05) (vla-put-textstring o (rtos aa 2 1)) (vla-put-textstring o (rtos aa 2 2)) ) ) ) (princ) ) (defun lm:roundto (n p) (lm:roundm n (expt 10.0 (- p)))) (defun lm:roundm (n m) (* m (atoi (rtos (/ n (float m)) 2 0)))) Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 12, 2018 Share Posted December 12, 2018 32 minutes ago, 1958 said: (if (<= aa 0.05) (vla-put-textstring o (rtos aa 2 1)) (vla-put-textstring o (rtos aa 2 2)) ) (vla-put-textstring o (rtos aa 2 (if (<= aa 0.05) 1 2))) 1 Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 12, 2018 Share Posted December 12, 2018 (edited) Note that rtos will round to the given precision, hence the code can become: (defun c:roundingz ( / i s v x ) (if (setq s (ssget "_:L" (cons '(0 . "*TEXT") (kg:SsgetFilterReal)))) (repeat (setq i (sslength s)) (setq i (1- i) x (entget (ssname s i)) v (assoc 1 x) ) (entmod (subst (cons 1 (rtos (atof (cdr v)) 2 (if (<= (atof (cdr v)) 0.05) 2 1))) v x)) ) ) (princ) ) (defun kg:SsgetFilterReal () ; Courtesy of Roy '( (1 . "~*[~-.0-9]*") ; only minus signs, decimal points and numbers allowed (1 . "*`.*") ; there must be one decimal point (1 . "~*`.*`.*") ; only one decimal point allowed (-4 . "<OR") (1 . "~*-*") ; there is no minus sign (-4 . "<AND") (1 . "-*") ; the minus sign must be the first character (1 . "~*-*-*") ; only one minus sign allowed (-4 . "AND>") (-4 . "OR>") ) ) (princ) My thanks to @Roy_043 for the useful ssget filter list function. Edited December 12, 2018 by Lee Mac Quote Link to comment Share on other sites More sharing options...
ktbjx Posted December 12, 2018 Author Share Posted December 12, 2018 10 hours ago, 1958 said: (defun c:roundingz (/ o s aa) (if (setq s (ssget ":L" '((0 . "*text")))) (foreach a (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (setq o (vlax-ename->vla-object a) aa (lm:roundto (atof (vla-get-textstring o)) 2) ) (if (<= aa 0.05) (vla-put-textstring o (rtos aa 2 1)) (vla-put-textstring o (rtos aa 2 2)) ) ) ) (princ) ) (defun lm:roundto (n p) (lm:roundm n (expt 10.0 (- p)))) (defun lm:roundm (n m) (* m (atoi (rtos (/ n (float m)) 2 0)))) thank you sir! now i know how it should look like using if statement... 10 hours ago, Tharwat said: (vla-put-textstring o (rtos aa 2 (if (<= aa 0.05) 1 2))) wow, you just made it even shorter! i will try this sir! thanks! 10 hours ago, Lee Mac said: Note that rtos will round to the given precision, hence the code can become: (defun c:roundingz ( / i s v x ) (if (setq s (ssget "_:L" (cons '(0 . "*TEXT") (kg:SsgetFilterReal)))) (repeat (setq i (sslength s)) (setq i (1- i) x (entget (ssname s i)) v (assoc 1 x) ) (entmod (subst (cons 1 (rtos (atof (cdr v)) 2 (if (<= (atof (cdr v)) 0.05) 2 1))) v x)) ) ) (princ) ) (defun kg:SsgetFilterReal () ; Courtesy of Roy '( (1 . "~*[~-.0-9]*") ; only minus signs, decimal points and numbers allowed (1 . "*`.*") ; there must be one decimal point (1 . "~*`.*`.*") ; only one decimal point allowed (-4 . "<OR") (1 . "~*-*") ; there is no minus sign (-4 . "<AND") (1 . "-*") ; the minus sign must be the first character (1 . "~*-*-*") ; only one minus sign allowed (-4 . "AND>") (-4 . "OR>") ) ) (princ) My thanks to @Roy_043 for the useful ssget filter list function. okay, this sir makes my life even easier! for filtering the strings out! i like this! its very useful. I dont have to manually check the text to be a number, ican just select them all and the routine will do the work! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 13, 2018 Share Posted December 13, 2018 23 hours ago, Tharwat said: (vla-put-textstring o (rtos aa 2 (if (<= aa 0.05) 1 2))) I think you have the then/else values switched Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted December 13, 2018 Share Posted December 13, 2018 13 hours ago, ktbjx said: Okay, this sir makes my life even easier! for filtering the strings out! i like this! its very useful. I dont have to manually check the text to be a number, ican just select them all and the routine will do the work! You're welcome! Quote Link to comment Share on other sites More sharing options...
Tharwat Posted December 13, 2018 Share Posted December 13, 2018 7 minutes ago, Lee Mac said: I think you have the then/else values switched I guess you are right although and as you can see, I just shortened the codes for the user 1958 and did not read OP's codes to check them out. Thanks for pointing that out. Quote Link to comment Share on other sites More sharing options...
