Extract Layout Name
Mystogan
Hi to all
Would like to know if there's a way to extract all the layout tab name?
I got series of layout name it will be easy for me to extract those layout tab name..
Thank you in advance.
Please explain more what you want to do with the names a few ideas come to  mind. It more than likely has been done.
GOTO layout, zoom all layouts, update titles in layout, plot range of layouts, rename layouts, reorder layouts to mention just a few.
I tried layoutlist command at autocad 2010, and it didn't work.
The goal is the same as extracting block object. Doing this using dataextraction command then this command will give me details on How many the block object is and if there is a double entry of name it will be easy to modify.
That's what I'm trying to achieve hopefully someone can give a lsp. it will be a great help
