antons99 Posted October 10, 2011 Share Posted October 10, 2011 when im switching my drawing into paper space and then trying to print it my drawing is massive and only small part of it id in the peper space any advice would be appreciated. many thanks???? Quote Link to comment Share on other sites More sharing options...
Dana W Posted October 10, 2011 Share Posted October 10, 2011 Have you selected a paper size for your plot? Are you using a scaled viewport? Naturally, a large object drawn at full size will not fit on paper. It will have to be scaled to fit your available paper size. Quote Link to comment Share on other sites More sharing options...
antons99 Posted October 10, 2011 Author Share Posted October 10, 2011 what im basically drawing is a 2.5 metre x 2.5 metre window frame in the drawing dimension of 1_2 but when i go to plot it all im getting on the preview is the bottom corner of my drawing and drawing template?? Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 10, 2011 Share Posted October 10, 2011 Welcome to the forum. Plotting is one of the hardest things to do in AutoCAD. Ideally, you want to scale your drawing down to fit in the layout in paper space. The layout is then plotted at 1 to 1, i.e. actual size of the paper (that's why they call it paper space). If your layout doesn't look like the plot you want, check the viewport scale. If your plot preview is off, check the paper size and the plotting scale. You may have to experiment to get the result you want. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 10, 2011 Share Posted October 10, 2011 Model space objects: draw FULL size. Paper space viewport: assign scale; lock the display. Paper space plot scale for metric users: 1 unit = 1 mm. Quote Link to comment Share on other sites More sharing options...
antons99 Posted October 10, 2011 Author Share Posted October 10, 2011 thanks for speedy reply! and thanks for the welcome!! but still struggling, i've gone right back to the beggining opened up cad , opened my new drawing with my paper template but evev when im opening my template that is even blown up so all i can see is the bottom corner, I dont no how to get that to normal size. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 10, 2011 Share Posted October 10, 2011 Zip and attach the file here. How to get correclty scaled viewports should have been covered in your class. The things I will be looking for in your file - Have you modeled 1:1 scale in modelspace. Have you set up your template so that you have appropriate border(s) at 1:1 scale in Paperspace Layouts. Have you selected an appropriate scale for your paperspace viewport. Viewport locked at appropriate scale. Set for your printer? Appropriate layer use? floaters and other issues? When a starting template is set up properly - you don't even need to do a Plot (print) Preview - you know with confidence that it will plot as intended. Set it once (your template) and forget it. Quote Link to comment Share on other sites More sharing options...
antons99 Posted October 10, 2011 Author Share Posted October 10, 2011 The situation I am in is the only cad expierince I have is at night school were i did my level 2, and paper space etc just wasnt covered. I have been asked to come off the tools and go to work in the office as the cad man has left giving me only 1 days quick show of what he does so my knowledge is very basic, and i dont even no how to zip the file. On friday when I was working with the cad man the template was fine. but now this morning i am opening it up and it blown up. As you can see i am in that deep end here ha Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 10, 2011 Share Posted October 10, 2011 The quicker you post the drawing the faster you'll get an answer. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 10, 2011 Share Posted October 10, 2011 In Windows Explorer right click on the filename and select Send to Compressed (zipped) Folder. Attach the resulting *.zip file here. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 11, 2011 Share Posted October 11, 2011 2.5 x 2.5 1/2 scale = 1.25m and A1 sheet is 841mm long so your still bigger with 1.25 you probably need 1/4 scale Draw a box in layout 800x560 this is a A1 sheet!!! Mview and create a window within it then zoom e zoom c 4XP them plot from paperspace at 1:1 scale use say window pick box preview should be correct now. Quote Link to comment Share on other sites More sharing options...
Misblkh Posted April 19 Share Posted April 19 I have drawing as an extra subject for my college degree and we weren't really taught much other than just a few tools. I am facing a similar issue here. When trying to export my drawing as a pdf it appears only at the base of the pdf and the rest of the top is blank. When I tried exporting again, my lines disappeared and only the dimensions were visible in the pdf, I need to submit the pdf by next week, NEED HELP PLEASE !! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 20 Share Posted April 20 Use say a window selection of objects to print, then use scale Fit this should produce something even if not at correct scale. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted April 24 Share Posted April 24 Select one of the layouts at the bottom of the window. You will see your paper space, possibly with a viewport included. If you don't have a viewport, use the VPORTS command to create one. Double-click in the viewport. That will put you in model space. Use the ZOOM Extents command. That should bring your linework into the center of the viewport. If you need to print to a scale, you'll have to adjust the viewport scale (one of its properties) or the size of the viewport itself or both. Once you have the viewport how you want it, plot it to your PDF plotter. The details will depend on the configuration of your system. It will take some experimentation the first time you do this. Don't be afraid to make mistakes. Welcome to the forum! Quote Link to comment Share on other sites More sharing options...
