DuanJinHui Posted May 4, 2016 Share Posted May 4, 2016 Use ""ssget" ,I want filter non-uniformly scaled block. (setq ss (ssget (list '(0 . "INSERT")))) Any good idea? Thanks. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 4, 2016 Share Posted May 4, 2016 Hi, You may need to change the value of 1.0 to your desired one. (setq ss (ssget '((-4 . "<NOT") (-4 . "<AND") (0 . "INSERT") (41 . 1.0) (42 . 1.0) (43 . 1.0) (-4 . "AND>") (-4 . "NOT>") ) ) ) Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 4, 2016 Author Share Posted May 4, 2016 Hi, You may need to change the value of 1.0 to your desired one. (setq ss (ssget '((-4 . "<NOT") (-4 . "<AND") (0 . "INSERT") (41 . 1.0) (42 . 1.0) (43 . 1.0) (-4 . "AND>") (-4 . "NOT>") ) ) ) Thanks Tharwat. But this is not I need. I need choose uniformly scaled blocks . eg. (41 . 1.0)(42 . 1.0)(43 . 1.0) (41 . 2.0)(42 . 2.0)(43 . 2.0) (41 . 3.0)(42 . 3.0)(43 .3.0).... etc. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 4, 2016 Author Share Posted May 4, 2016 I know use "entsel" function can do this: (setq blkref (car (entsel "\n>>>Choose a block:"))) (if (not(= (cdr(assoc 41 (entget blkref))) (cdr(assoc 42 (entget blkref))) (cdr(assoc 43 (entget blkref))))) (progn (alert "\nNOT support non-uniformly scaled block.") t ) (progn Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 4, 2016 Share Posted May 4, 2016 I am really not sure that you can filter many blocks with different scale values of X,Y and Z but you can have only one as I've demonstrated in the first reply. Otherwise you can make a selection set of blocks then cycle through each block object and add objects to a list when their scales X,Y,Z are matched. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 4, 2016 Author Share Posted May 4, 2016 I am really not sure that you can filter many blocks with different scale values of X,Y and Z but you can have only one as I've demonstrated in the first reply. Otherwise you can make a selection set of blocks then cycle through each block object and add objects to a list when their scales X,Y,Z are matched. Maybe need write a sub-function. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 4, 2016 Share Posted May 4, 2016 Maybe need write a sub-function. Try it and let me know if you need any help. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 4, 2016 Author Share Posted May 4, 2016 Try it and let me know if you need any help. Maybe need 1 day or more . I will try . Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 4, 2016 Share Posted May 4, 2016 Maybe need 1 day or more . I will try . Nooo, it is simple. If you don't try and give at least 75% of codes correct, I won't reply to any of your threads anymore. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 4, 2016 Author Share Posted May 4, 2016 (edited) Nooo, it is simple. If you don't try and give at least 75% of codes correct, I won't reply to any of your threads anymore. This ? Any suggestions ? Thanks. (defun newss(/ ss i ename ) (while (if (null(setq ss (ssget (list '(0 . "INSERT"))))) (progn (alert "\nNothing select. Try again.") t ) (progn (repeat (setq i (sslength ss)) (setq ename (ssname ss (setq i (1- i)))) (if (not (= (cdr(assoc 41 (entget ename)))(cdr(assoc 42 (entget ename)))(cdr(assoc 43 (entget ename)))) ) (setq ename(ssdel ename ss)) ) ) nil ) ) ) ename ) So,if need use this new selection set. ; test (setq en (newss)) (command "_.move" en "") Edited May 4, 2016 by DuanJinHui Add testing code. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted May 4, 2016 Share Posted May 4, 2016 So far so good You don't need the while function and the return of the function must be the variable ss and not the entity name and a few little mods. Keep on coding and no matter how many mistakes you would have. Take a look. (defun newss (/ ss i ename) (if (setq ss (ssget (list '(0 . "INSERT")))) (repeat (setq i (sslength ss)) (setq ename (ssname ss (setq i (1- i)))) (if (not (= (cdr (assoc 41 (entget ename))) (cdr (assoc 42 (entget ename))) (cdr (assoc 43 (entget ename)))) ) (ssdel ename ss) ) ) (alert "\nNothing select. Try again.") ) ss ) Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 4, 2016 Share Posted May 4, 2016 (edited) Maybe : [b][color=BLACK]([/color][/b]defun c:noteq [b][color=FUCHSIA]([/color][/b]/ ss i en ed[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq neq [b][color=NAVY]([/color][/b]ssadd[b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget [color=#2f4f4f]"X"[/color] [b][color=GREEN]([/color][/b]list [b][color=BLUE]([/color][/b]cons 0 [color=#2f4f4f]"INSERT"[/color][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq i 0[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]if [b][color=GREEN]([/color][/b]not [b][color=BLUE]([/color][/b]= [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 41 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 42 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]cdr [b][color=PURPLE]([/color][/b]assoc 43 ed[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]ssadd en neq[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq i [b][color=GREEN]([/color][/b]1+ i[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]alert [b][color=NAVY]([/color][/b]strcat [color=#2f4f4f]"UnEqual Scaked Blocks Found = "[/color] [b][color=MAROON]([/color][/b]rtos [b][color=GREEN]([/color][/b]sslength neq[b][color=GREEN])[/color][/b] 2 0[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] global neq PICKSET -David Edited May 5, 2016 by David Bethel Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 5, 2016 Share Posted May 5, 2016 Using VL easy to just compare X & Y & Z etc dont need to remember the assoc code ; XEffectiveScaleFactor = 1.0 ; XScaleFactor = 1.0 ; YEffectiveScaleFactor = 2.0 ; YScaleFactor = 2.0 ; ZEffectiveScaleFactor = 1.0 ; ZScaleFactor = 1.0 Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 5, 2016 Author Share Posted May 5, 2016 Thanks Tharwat and David . Hi David. My drawing have non-uniformly scaled block. I use your code for testing. But alert "UnEqual Scaled Blocks Found=0" Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 5, 2016 Share Posted May 5, 2016 Hi David. My drawing have non-uniformly scaled block. I use your code for testing. But alert "UnEqual Scaled Blocks Found=0" My bad, I forgot /= has a quirk in that (/=1 2 2) returns nil. I fixed the code in post #12 -David Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 5, 2016 Share Posted May 5, 2016 Do you want to select non-uniformly scaled blocks but ignore mirrored blocks (i.e. for which the x-scale factor is negative)? Since the block scale is stored as a double, I would recommend using the equal function with some tolerance when performing the comparison, i.e.: (defun c:selnublocks ( / i s x ) (if (setq s (ssget "_X" (list '(0 . "INSERT") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))) (repeat (setq i (sslength s)) (setq x (entget (ssname s (setq i (1- i))))) (if (and (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 42 x))) 1e- (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 43 x))) 1e- ) (ssdel (cdr (assoc -1 x)) s) ) ) ) (sssetfirst nil s) (princ) ) Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 6, 2016 Author Share Posted May 6, 2016 Do you want to select non-uniformly scaled blocks but ignore mirrored blocks (i.e. for which the x-scale factor is negative)? Since the block scale is stored as a double, I would recommend using the equal function with some tolerance when performing the comparison, i.e.: (defun c:selnublocks ( / i s x ) (if (setq s (ssget "_X" (list '(0 . "INSERT") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))) (repeat (setq i (sslength s)) (setq x (entget (ssname s (setq i (1- i))))) (if (and (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 42 x))) 1e- (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 43 x))) 1e- ) (ssdel (cdr (assoc -1 x)) s) ) ) ) (sssetfirst nil s) (princ) ) I ignore mirrored blocks. Many Thanks Lee. If I want select uniformly scaled blocks, Just replace "equal" to "/=" , Right ? Mention mirrored blocks ,I reminded a question. http://www.cadtutor.net/forum/showthread.php?96562-Lee-s-MirrorBlock.lsp-have-a-bug Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 6, 2016 Share Posted May 6, 2016 I ignore mirrored blocks. Many Thanks Lee. If I want select uniformly scaled blocks, Just replace "equal" to "/=" , Right ? I would suggest enclosing the (and) expression with a (not) to reverse the condition. Quote Link to comment Share on other sites More sharing options...
DuanJinHui Posted May 6, 2016 Author Share Posted May 6, 2016 I would suggest enclosing the (and) expression with a (not) to reverse the condition. Lee,Thank you again. Like this? (if (not (and (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 42 x))) 1e- (equal (abs (cdr (assoc 41 x))) (abs (cdr (assoc 43 x))) 1e- ) ) (ssdel (cdr (assoc -1 x)) s) ) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 6, 2016 Share Posted May 6, 2016 Exactly Quote Link to comment Share on other sites More sharing options...
