I have chamfered everythign I could. But the rest I cant get to work.
Why???
sman.dwg
Because your chamfer distance of 1/8" cause a problem. I was able to get it to chamfer with a distance of 1/64".
then y was I able to do the rest?
It's the remaining part that is causing a problem. I think it has to do with the size of the chamfer failing when it tries to remove a part of the other chamfer, kind of like it's conflicting with it.
One thing you could try is to chamfer all of the edges at once. I've had luck doing that in the past, but I've never tried it on a Superman logo.
