Hello everyone
Two questions:
- Ortho, osnap, polar and all of the other buttons with letter in previous versions are now icons. Can these be turned back to letter buttons? These icons are just plain unclear to me. With letters one can see at a glance what is turned on and off.
- Can the delay time for rollover tooltips be changed?
Thanks in advance!
Re: delay time. Is this what you are referring to?
Tools > Options > Display tab under Window Elements. Sow Tool Tips > Number of seconds to delay.
Re: icons.
I'm not aware of an AutoCAD available option for changing the icon buttons from a graphic to a letter. If there is such an option maybe someone else knows how to access it. If there isn't then I guess the cui could be editted and icon buttons with letters on them substituted? Don't know for sure.
No, this is for tool tips. I'm asking about rollover tooltips. Tips that pop out when you hover over objects in a drawing.
Sorry.
Instead of changing the delay time you might just want to turn this feature off (along with a few others) to improve 2010 performance.
Actually i don't have an issue with its performance, but i often need those rollover tooltips to display instantly, without delay.
In 2007 i used this http://www.bubblecad.com/en/bubble.htm
Maybe will switch back to it.
Options, Display, Number of seconds to delay (toolTips)
Right click on one of the icons and uncheck "use icons"
"Ortho, osnap, polar and all of the other buttons with letter in previous versions are now icons. Can these be turned back to letter buttons? These icons are just plain unclear to me. With letters one can see at a glance what is turned on and off"
Just do the right click on these buttons and unmark "use icons" and they'll become with letters
No, not tooltips, rollover tooltips. Two different things.
Oh man, embarrassed :oops:
