Michael Balcomb Posted August 24, 2009 Posted August 24, 2009 Has anyone been able to make the 2010MEP Profiles alterations hold after resetting and re-starting MEP. I have set my MEP to Acad on the profiles options and then set the display workspace to Classic and on exit select to save the Drawing1.dwg file. On restarting the system continualy opens as MEP Global and not Acad as set, any hints? Quote
Rsblades Posted August 24, 2009 Posted August 24, 2009 Has anyone been able to make the 2010MEP Profiles alterations hold after resetting and re-starting MEP. I have set my MEP to Acad on the profiles options and then set the display workspace to Classic and on exit select to save the Drawing1.dwg file. On restarting the system continualy opens as MEP Global and not Acad as set, any hints? I dont use MEP i use C3D and have used LDD and regular ACAD (Land Enabled Map I think) and they are all the same so far.. you have to set the profile and the workspace to default (profile is set in CUI for the versions ive used and workspace is set to default in the same place where you set it to current (workspace settings or something like that)). Hope this helps. Quote
