mexxx_ Posted August 13, 2009 Posted August 13, 2009 Sorry but my English is not well. I have also a question: How can I delete the invisible attributes by the command “BURST”? I have a block which attributes and some of them are invisible and if I explode the block with "BURST" they are as text near the explodet block how can I delet them by a lisp with out to select them separate? Quote
Lee Mac Posted August 13, 2009 Posted August 13, 2009 I wrote this a while back, for users that didn't have ET, but also as a learning exercise, see if it works for you: [i][color=#990099];; MacBurst ~ An Alternative Burst LISP by Lee Mac[/color][/i] [i][color=#990099];; Copyright (c) 03.06.2009[/color][/i] [i][color=#990099];; Updated: 13.08.2009[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:MacBurst [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss iPt lst aLst Obj[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\nInitializing..."[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] doc [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"INSERT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-StartUndoMark[/color][/b] doc[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] Blk [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] iPt [b][color=RED]([/color][/b][b][color=BLUE]vlax-3D-point[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] aLst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vlax-vla-object->ename[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-invoke[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] Obj [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b]GetAttributes[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-invoke[/color][/b] Obj [b][color=DARKRED]'[/color][/b]GetConstantAttributes[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-move[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-ename->vla-object[/color][/b] x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vlax-3D-point[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] iPt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]append[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entmakex[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"ATTDEF"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b]GetObj [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entmakex[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]y[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] x[b][color=RED])[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]100[/color][/b] [b][color=#009900]3[/color][/b] [b][color=#009900]2[/color][/b] [b][color=#009900]70[/color][/b] [b][color=#009900]280[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] y[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]2[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b] aLst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"TEXT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]73[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]74[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]74[/color][/b] x[b][color=RED])[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if-not[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=#ff00ff]"ATTDEF"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]zerop[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]logand[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]70[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entdel[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-EndUndoMark[/color][/b] doc[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Get Block Sub-Entities[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GetObj [b][color=RED]([/color][/b]bObj[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bObj [b][color=RED]([/color][/b][b][color=BLUE]entnext[/color][/b] bObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] bObj [b][color=RED]([/color][/b]GetObj bObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
VVA Posted August 13, 2009 Posted August 13, 2009 >mexxx_ This is one of the bugs Express Tools. This bugs is described, and corrected me on the Russian-language forum. I published file burstfix.rar (burstfix.zip it here). This 2 files: burstfix.dwg - example burstfix.lsp - corrected file burst.lsp. Load burstfix.lsp to Acad and try again BURST. Update 2009.10.11 Fixed bug with list burstfix.ZIP Quote
Lee Mac Posted August 13, 2009 Posted August 13, 2009 yes thanks it works Did mine work, or were you referring to VVA's? *just curious* Quote
mexxx_ Posted August 13, 2009 Author Posted August 13, 2009 the burstfix from VVA works your lisp has a problem with the dynamical block but also thanks for your post Quote
Lee Mac Posted August 13, 2009 Posted August 13, 2009 the burstfix from VVA works your lisp has a problem with the dynamical block but also thanks for your post Ahh, I hadn't accounted for a dynamic block - but thank you for testing it Quote
mexxx_ Posted October 7, 2009 Author Posted October 7, 2009 hallo, the burstfix lisp has a problem with the dynamical block and invisible attributes the block has been attached can anyone help me please? noBurst.zip Quote
VVA Posted October 12, 2009 Posted October 12, 2009 hallo, the burstfix lisp has a problem with the dynamical block and invisible attributes the block has been attached can anyone help me please? Update #3. Try it again Quote
