tommye999 Posted May 12, 2009 Posted May 12, 2009 Hi, just wondering if anyone had come across an issue when importing OS mastermap data gz files using the mapimport function. It doesnt happen to all files but just one batch recieved from the ordinancesurvey guys. It chugs away importing objects very slowly and then has an unhandled exception - FATAL ERROR: Unhandled e06d7363h Exception at 7c812afbh 05/12/2009 at 15:02:11.628 Drawing: Drawing2.dwg Any ideas would be fantastic Tom Quote
NBC Posted May 12, 2009 Posted May 12, 2009 Is this of any use - http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=9450349&linkID=9240617 Quote
tommye999 Posted May 13, 2009 Author Posted May 13, 2009 Thanks for the pointer, didnt fix the issue unfortunately, any other ideas? Tom Quote
thanos79 Posted November 10, 2009 Posted November 10, 2009 tommye999 did you find any solution with this headache with name "fatal error:unhanled e06d7363h exception at 7c812afbh " i have problem with autocad arhitecture 2009!please help!!!! Quote
