Thomy Posted March 30, 2009 Posted March 30, 2009 Hi, I 'm traying to get aan example of te numbers that I insert in my VBA program. But It may not be a picture I want that I can see the changes that I make to improve the drawing. I thought bij a button witch i link to te drawing command's en every time I click on the button it delet's the drawing and redraw's it with the new data. sorry for my bad langauge. I 'm not good in using diferent langauge's. Regard's thomy Quote
Lee Mac Posted March 30, 2009 Posted March 30, 2009 Not sure quite what you are after Thomy - sounds like a thumbnail of changes, but could you clarify it further please :wink: Quote
Thomy Posted March 31, 2009 Author Posted March 31, 2009 hi, I want a example screen from te frame I fill in. But when I change some data that I fill in. I want to see it change on my screen. Quote
Lee Mac Posted March 31, 2009 Posted March 31, 2009 hi, I want a example screen from te frame I fill in. But when I change some data that I fill in. I want to see it change on my screen. If I understand it correctly, you would like a "preview" screen to update as you type your VBA code - not an easy task if I am correct... Quote
Thomy Posted March 31, 2009 Author Posted March 31, 2009 Hi, yes somting like that. only not when I'm typing my VBA code but when I use my VBA program. like I give a height and width in and then I want to see a preview from my drawing. so that I can sjange it if it isn't correct for mee. Quote
Thomy Posted March 31, 2009 Author Posted March 31, 2009 If I understand it correctly, you would like a "preview" screen to update as you type your VBA code - not an easy task if I am correct... Hi, yes somting like that. only not when I'm typing my VBA code but when I use my VBA program. like I give a height and width in and then I want to see a preview from my drawing. so that I can sjange it if it isn't correct for mee. Quote
