nocturne00 Posted September 24, 2008 Posted September 24, 2008 anybody ever experienced this? Command: GATTE Initializing... Select block or attribute [block name]: Known tag names for block: R# PF ST# D C B A ST4 ST3 ST2 ST1 T1 Select attribute or type attribute name: R# Block: *U276 Attribute tag: R# Enter new text: RA Number of inserts in drawing = 0 Process all of them? [Yes/No] : Y 0 attributes changed. we have an attributed TB and we need to update the revision number attribute with tag R#. problem is as you can see, it listed 0 under number of inserts, and there should be about 20+ of it to chance coz there's 20+ TB's with that attribute to update. Any help would be greatly appriciated. Thanks Quote
nocturne00 Posted September 24, 2008 Author Posted September 24, 2008 I think i may have found out the cause, but dont have an Idea on how to fix it. It seems that when the TB is copied its name changes with something like *U240 or something like that. these copied title blocks dont get included when you use the GATTE command although they are the same with the original. Quote
avguy Posted September 21, 2010 Posted September 21, 2010 Simply explode it and make it a block again, it will work! Quote
