How to check if color of object is set to rgb
ziele_o2k
As topic says, how to check if object color is set to rgb.
For example if I will manually set rgb color to 255,255,0 (yellow) - how to verify that this is true color and not aci?
...And without DXF 430 (Colour Book)
(defun rgb-p ( ent / enx )
   (and (setq enx (entget ent))
        (assoc 420 enx)
        (not (assoc 430 enx))
In meantime I started digging and I have new knowledge about true colors in acad :)
(defun rgb-p ( obj / c )
 (and
   (=  (vla-get-colormethod (setq c (vla-get-truecolor obj)))
       194
   (= (vla-get-ColorName c) "")
Heres how I'd write it:
; (rgbp (vlax-ename->vla-object (car (entsel))))
(defun rgbp ( o / c r )
 (and
   (setq c (vlax-get o 'TrueColor))
   (eq (vlax-get c 'ColorMethod) acColorMethodByRGB)
   (eq (vlax-get c 'ColorName) "")
   (setq r (mapcar ''((x) (vlax-get c x)) '(Red Green Blue)))
 ); and
 (and c (vl-catch-all-apply 'vlax-release-object (list c)))
 r
); defun rgbp
But I'm not sure if the true color object property has to be released, justin case approach..
And would return either the rgb value or nil (if you require boolean return your will be faster).
In reference to Autolisp help:
When an AutoLISP routine no longer uses an object outside AutoCAD, such as a Microsoft Excel object, call the vlax-release-object function to make sure that the associated application closes properly.
So in my opinion you do not have to release color object because this is existing object and you are reading only it's properties.
But now I have question, when do you guys are using vlax-release-object.
I'm doing that only when I'm:
- making truecolor object "AutoCAD.AcCmColor...."
- playing with Excel
- playing with XML
