Hello all,
I made a lisp with a routine from Lee Mac. (select by att value)
The intention is to count the number of modules (same block name). It concerns "EIDS, ETV and IO"
It works partially. If I have all the type of modules in the drawing, then it will be fine. But as soon as I remove a type, then the lisp still indicates "OPT11". What am I doing wrong?
I do not know what to use in the section (if (and ..... if none: "", "0" or nil.
I used 3 times Lee's lisp to select by attribute value.
Is it going wrong here? Can this (3x Lee lisp) be replaced by 1 routine and that outcomes are stored in the variables (setq) "EIDS", "ETV" "IO" ?.
;	Module counting     "MOD-COUNT" to run
;------------- Count EIDS -------------
;; Select Blocks by Attribute Value  -  Lee Mac
;; Selects all attributed blocks in the current layout which contain a specified attribute value.
(defun c:EIDS ( / att atx ent idx sel1 str1 )
   (if (/= "" (setq str1 "EIDS"))
       (if (and
               (setq sel1
                   (ssget "_X"
                       (list '(0 . "INSERT") '(66 . 1)
                           (if (= 1 (getvar 'cvport))
                               (cons 410 (getvar 'ctab))
                              '(410 . "Model")
                   (repeat (setq idx (sslength sel1))
                       (setq ent (ssname sel1 (setq idx (1- idx)))
                             att (entnext ent)
                             atx (entget  att)
                       (while
                           (and (= "ATTRIB" (cdr (assoc 0 atx)))
                                (not (wcmatch (strcase (cdr (assoc 1 atx))) str1))
                           (setq att (entnext att)
                                 atx (entget  att)
                       (if (= "SEQEND" (cdr (assoc 0 atx)))
                           (ssdel ent sel1)
                   (< 0 (sslength sel1))
           (sssetfirst nil sel1)
           (princ (strcat "\nNo blocks found with attribute value matching \"" str1 "\"."))
(progn (setq n (sslength sel1))
(setq EIDS (itoa n))
;------------- Count ETV -------------
(defun c:ETV ( / att atx ent idx sel2 str2 )
   (if (/= "" (setq str2 "ETV"))
       (if (and
               (setq sel2
                   (ssget "_X"
                              '(410 . "Model")
                   (repeat (setq idx (sslength sel2))
                       (setq ent (ssname sel2 (setq idx (1- idx)))
                             att (entnext ent)
                             atx (entget  att)
                       (while
                                (not (wcmatch (strcase (cdr (assoc 1 atx))) str2))
                                 atx (entget  att)
                           (ssdel ent sel2)
                   (< 0 (sslength sel2))
           (sssetfirst nil sel2)
           (princ (strcat "\nNo blocks found with attribute value matching \"" str2 "\"."))
(progn (setq n (sslength sel2))
(setq ETV (itoa n))
;------------- Count IO -------------
(defun c:IO ( / att atx ent idx sel3 str3 )
   (if (/= "" (setq str3 "I/O"))
       (if (and
               (setq sel3
                   (ssget "_X"
                              '(410 . "Model")
                   (repeat (setq idx (sslength sel3))
                       (setq ent (ssname sel3 (setq idx (1- idx)))
                             att (entnext ent)
                             atx (entget  att)
                       (while
                                (not (wcmatch (strcase (cdr (assoc 1 atx))) str3))
                                 atx (entget  att)
                           (ssdel ent sel3)
                   (< 0 (sslength sel3))
           (sssetfirst nil sel3)
           (princ (strcat "\nNo blocks found with attribute value matching \"" str3 "\"."))
(progn (setq n (sslength sel3))
(setq IO (itoa n))
; ------------- Set Amount -------------
(defun c:amount ()
(if (and (= EIDS nil)	(= ETV "1")	(= IO nil))	(setq Module "OPT1"))
(if (and (= EIDS "1")	(= ETV nil)	(= IO nil))	(setq Module "OPT2"))
(if (and (= EIDS "1")	(= ETV nil)	(= IO "1"))	(setq Module "OPT3"))
(if (and (= EIDS "1")	(= ETV nil)	(= IO "2"))	(setq Module "OPT4"))
(if (and (= EIDS "1")	(= ETV nil)	(= IO "3"))	(setq Module "OPT5"))
(if (and (= EIDS "1")	(= ETV nil)	(= IO "4"))	(setq Module "OPT6"))
(if (and (= EIDS "1")	(= ETV nil)	(= IO "5"))	(setq Module "OPT7"))
(if (and (= EIDS "1")	(= ETV "1")	(= IO nil))	(setq Module "OPT8"))
(if (and (= EIDS "1")	(= ETV "1")	(= IO "1"))	(setq Module "OPT9"))
(if (and (= EIDS "1")	(= ETV "1")	(= IO "2"))	(setq Module "OPT10"))
(if (and (= EIDS "1") 	(= ETV "1")	(= IO "3"))	(setq Module "OPT11"))
;(setenv 'USER1' ")
;(setenv'USER1' Module)
;(setq USl (getenv'USER1'))
(alert module); to test
i------------- Main / Run -------------
(defun c:test ()
;(setq EIDS nil)
;(setq ETV nil)
;(setq IO nil)
;(setq amount nil)
(c:EIDS)
(c:ETV)
(c:IO)
(c:amount)
thank you in advance
PmxCAD
floor-plan.dwg
Just a bit of a guess add an extra IF you dont check for not exists.
(if (= module nil)((setq module "Not found"))
Edited by BIGAL
Hi BIGAL,
thanks you for your response, but it has been solved. So it had to be "0".
       (if (and
               (setq sel1
                   (ssget "_X"
                              '(410 . "Model")
                             att (entnext ent)
                             atx (entget  att)
                       (while
                                 atx (entget  att)
                           (ssdel ent sel1)
(progn (setq n1 (sslength sel1))
(setq EIDS (itoa n1))
;(alert eids)
       (if (and
               (setq sel2
                   (ssget "_X"
                              '(410 . "Model")
                             att (entnext ent)
                             atx (entget  att)
                       (while
                                 atx (entget  att)
                           (ssdel ent sel2)
(progn (setq n2 (sslength sel2))
(setq ETV (itoa n2))
;(alert etv)
       (if (and
               (setq sel3
                   (ssget "_X"
                              '(410 . "Model")
                             att (entnext ent)
                             atx (entget  att)
                       (while
                                 atx (entget  att)
                           (ssdel ent sel3)
;            (princ (strcat "\nNo blocks found with attribute value matching \"" str3 "\"."))
(progn (setq n3 (sslength sel3))
(setq IO (itoa n3))
;(alert io)
(defun c:amount ()
(if (and (= EIDS "0")    (= ETV "1")    (= IO "0"))    (setq Module "OPT1"))
(if (and (= EIDS "1")    (= ETV "0")    (= IO "0"))    (setq Module "OPT2"))
(if (and (= EIDS "1")    (= ETV "0")    (= IO "1"))    (setq Module "OPT3"))
(if (and (= EIDS "1")    (= ETV "0")    (= IO "2"))    (setq Module "OPT4"))
(if (and (= EIDS "1")    (= ETV "0")    (= IO "3"))    (setq Module "OPT5"))
(if (and (= EIDS "1")    (= ETV "0")    (= IO "4"))    (setq Module "OPT6"))
(if (and (= EIDS "1")    (= ETV "0")    (= IO "5"))    (setq Module "OPT7"))
(if (and (= EIDS "1")    (= ETV "1")    (= IO "0"))    (setq Module "OPT8"))
;(setenv 'USER1' ")
(alert module)
(defun c:MOD-COUNT ()
(c:EIDS)
(c:ETV)
(c:IO)
(c:amount)
PmxCAD
Here's another way to approach it (untested):
;; Count Blocks by Attribute Value  -  Lee Mac
(defun CountBlocksByAttribValue ( lst / att atx ent idx itm key rtn sel )
   (if (setq lst (mapcar 'strcase lst)
             sel (ssget "_X" (list '(0 . "INSERT") '(66 . 1) (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model"))))
       (repeat (setq idx (sslength sel))
           (setq ent (ssname  sel (setq idx (1- idx)))
                 att (entnext ent)
                 atx (entget  att)
           (while (= "ATTRIB" (cdr (assoc 0 atx)))
               (cond
                   (   (not (member (setq key (strcase (cdr (assoc 1 atx)))) lst)))
                   (   (setq itm (assoc key rtn))
                       (setq rtn (subst (cons key (1+ (cdr itm))) itm rtn))
                   (   (setq rtn (cons (cons key 1) rtn)))
                     atx (entget  att)
   rtn
(defun c:test ( / key lst )
   (setq key '("EIDS" "ETV" "I/O")
         lst  (CountBlocksByAttribValue key)
   (cdr
       (assoc (mapcar '(lambda ( k ) (cond ((cdr (assoc k lst))) (0))) key)
               ((0 1 0) . "OPT1")
               ((1 0 0) . "OPT2")
               ((1 0 1) . "OPT3")
               ((1 0 2) . "OPT4")
               ((1 0 3) . "OPT5")
               ((1 0 4) . "OPT6")
               ((1 0 5) . "OPT7")
               ((1 1 0) . "OPT8")
               ((1 1 1) . "OPT9")
               ((1 1 2) . "OPT10")
               ((1 1 3) . "OPT11")
It is again a nice clear routine Lee, as usual.
The result is now on command line, can it also be stored in a variable (setq)?
PmxCAD
Certainly - (setq xxx (cdr (assoc ...
(I'm sure you could have figured this one out ;) )
Yeb..solved.
Thanks Lee.
"Model"))))
                 att (entnext ent)
                 atx (entget  att)
               (cond
                     atx (entget  att)
   rtn
   (setq result (cdr
               ((0 1 0) . "OPT1")
               ((1 0 0) . "OPT2")
               ((1 0 1) . "OPT3")
               ((1 0 2) . "OPT4")
               ((1 0 3) . "OPT5")
               ((1 0 4) . "OPT6")
               ((1 0 5) . "OPT7")
               ((1 1 0) . "OPT8")
               ((1 1 1) . "OPT9")
               ((1 1 2) . "OPT10")
               ((1 1 3) . "OPT11")
