Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Go Back   AutoCAD Forums > AutoCAD > AutoCAD 3D Modelling & Rendering
Reply
Thread Tools
Old 15th Aug 2009, 03:25 am   #1
arjun_samar
Senior Member
arjun_samar's Avatar
Using: AutoCAD 2009
Default sun VS spot light
ok, here some render test...
same 3d scene
same render settings.
but one is sun & sky illimination
and the other spot light (used to simulate sun)
what are your judgement?
sun? or spot light?
arjun_samar is offline   Reply With Quote
Old 15th Aug 2009, 06:11 am   #2
Noahma
Super Member
Using: Architecture 2009
Default
I think the Sun & Sky is giving a more realistic look. The spotlight is giving a more even light though.
Noahma is offline   Reply With Quote
Old 15th Aug 2009, 07:42 am   #3
nocturne00
Super Member
nocturne00's Avatar
Using: AutoCAD 2009
Computer Details
Default
Sun and Sky here.
Spotlight will slightly deter the shadows from their right direction, sort of producing light at a radial direction, hence the shadows will be cast in an unnatural direction (as seen in the first render), unless you place it very distant from the model.
im not sure about this but I think there is a way to make the shadows cast by the sun look sharp,like the one cast by the spotlight.ill try to get back on this
....always perform Beyond what is expected.
nocturne00 is offline   Reply With Quote
Old 15th Aug 2009, 08:09 am   #4
arjun_samar
Senior Member
Using: AutoCAD 2009
Default
ok, thanks for the reply.
standing.
2 points for sun
0 point for spot light
Old 15th Aug 2009, 05:50 pm   #5
CadDan
Senior Member
CadDan's Avatar
Using: AutoCAD 2010
Computer Details
Default
I'm going for the sun. Reason being is that it looks more realistic
and if I was to walk into a building, that is how it would be portrayed.
"Man is a tool-using animal ... without tools he is nothing, with tools he is all."
"Doing easily what others find difficult is talent"
CadDan is offline   Reply With Quote
Old 16th Aug 2009, 01:18 am   #6
arjun_samar
Senior Member
Using: AutoCAD 2009
Default
standing.
3 points for the sun
0 point for the spot light...
oh my...... spot light is down by 3 points...
Old 6th Nov 2009, 09:26 am   #7
iskalipsi
Forum Newbie
iskalipsi's Avatar
Using: AutoCAD 2009
Default
hello, this is my first post.i have tried to use sunlight but cant get the result i wanted. may i ask whats the intensity of your spotlight?
thanks.
iskalipsi is offline   Reply With Quote
Old 7th Nov 2009, 03:20 am   #8
arjun_samar
Senior Member
Using: AutoCAD 2009
Default
Quote:
thanks.
I cant remember, the file was deleted a long time ago, but from the top of my head the intinsity of the spot light shouldn't be lower than 30-40, and spot light is more time consuming than the sun, and the sun can give more natural shadows than the spot light, but its your call.. its up to you sun or spot light. and feel free to ask.
Old 7th Nov 2009, 05:58 am   #9
Cad64
Super Moderator
Cad64's Avatar
Using: AutoCAD 2008
Computer Details
Default
Hmmmm, I'm not sure why your lighting is so blown out in the spotlight render? Something is definitely wrong there. And your Sun & Sky render is blotchy. I think you need more photons.
Below are two quick renders I just did in Studio Max. One using a Directional light with FG & GI enabled, (Never use a spotlight as your main light source/sunlight), and one using a Daylight System, (Similar to Autocad's "Sun & Sky").
As you can see, they look almost identical except for two things.
1. The Daylight System render took 1:25 to finish, but the Directional Light render took only 0:59 to finish.
2. The Daylight System render looks very grey and washed out, but the Directional Light render looks much more lively and vibrant.
I never use the Daylight System because everything is too automatic and I feel like I don't really have much control over the final rendered image. This was just a quick test, but with a good lighting set up and some tweaking of the settings, you can produce renders that look better than the Daylight System/Sun & Sky.
"Work Smart, Not Hard"
My Personal Portfolio ( Updated 10/25/09 ): http://www.rdeweese.com/
Cad64 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Accuracy not spot on. JamesP AutoCAD Beginners' Area 13 7th Jun 2009 10:58 am
Shaped light source - i.e., fluorescent light bulb SaigoLives AutoCAD 3D Modelling & Rendering 0 2nd Apr 2009 10:29 pm
Spot Heights PasMan AutoLISP, VBA, the CUI & Customisation 15 11th Feb 2008 08:17 pm
Spot light and its target nscherneck AutoCAD 3D Modelling & Rendering 1 21st Jun 2007 11:30 pm
spot heights ollylandandwater AutoCAD General 1 24th Apr 2007 01:55 pm
Why Donate?
RSS Feed for AutoCAD ForumsValid XHTML 1.0!Valid CSS!Creative Commons Licence
