Divide by custom property
Nickvnlr
I have this line of code and for the life of me I cannot figure out how to divide by a custom drawing property called "ROW SPACING".
...other stuff
(list (list "Total Risers:" (strcat "%<\\AcExpr (Sum(B3:B" (itoa (setq r (+ (length (car x)) 2))) "))/12 \\f \"%lu2%pr0\">%")))
;;replace 12 with the drawing property "ROW SPACING"
...other stuff
How would I do that?  Thank you!
Put the value of ROW SPACING in the variable RS, and run this code:
		    (strcat "))/" (itoa RS) " \\f \"%lu2%pr0\">%")
It should work...
I put the ROW COUNT into RS Like so:
(setq RS (getvar "ROW SPACING"))
And then the rest of the suggested code change.
That gives me this error:
Error: bad argument type <NIL> ; expected <INTEGER> at [itoa]
Edited by Nickvnlr
added detail
I fixed it.
To retrieve a custom property:
(setq si (vla-Get-SummaryInfo (vla-Get-ActiveDocument (vlax-Get-Acad-Object))))
(vla-GetCustomByKey si "ROW SPACING" 'RS) ;;get "ROW SPACING" set to variable RS
Since RS is already a string the line will look like this:
(list (list "Total Risers:" (strcat "%<\\AcExpr (Sum(B3:B" (itoa (setq r (+ (length (car x)) 2))) "))/" RS "\\f \"%lu2%pr0\">%")))
