why my code doesn't work ?
Petar_Grozni
Hello all,
I am bit frustrated with autolisp. Tried my first coding and i cannot see what is wrong.
I am trying to make automated array of rectangles, where i define dimensions of rectangle, number of rows, columns , and spacing between them.
Here is the code Ive written.
Yet, when I start it, after entereing parameters, i need to click in and get wierd results. here is the code, if you could hepl me i would really appreciate it
Thanx
Petar from Croatia
(defun c:stamps (/ w h c r a b)
  (setq w (getreal "\nEnter the width of the rectangle: "))
  (setq h (getreal "\nEnter the height of the rectangle: "))
  (setq c (getint "\nEnter the number of columns: "))
  (setq r (getint "\nEnter the number of rows: "))
  (setq a (getreal "\nEnter the distance between columns: "))
  (setq b (getreal "\nEnter the distance between rows: "))
  (setq startX 0)
  (setq startY 0)
  (repeat r
    (setq startX 0)
    (repeat c
      (command "_RECTANG" startX startY (+ startX w) (+ startY h))
      (setq startX (+ startX (+ w a)))
    (setq startY (+ startY (+ h b)))
Edited by SLW210
Added Code Tags!
@Petar_Grozni Try This:
  (setq startX 0)
  (setq startY 0)
  (repeat r
    (setq startX 0)
    (repeat c
      ;; You nead to disable object snaps before points using "non" override, and coordinates should be a point list, not just separate x and y values.
      (command "_RECTANG" "_non" (list startX startY) "_non" (list (+ startX w) (+ startY h)))
@Petar_Grozni Here is a better way to write it FWIW:
(defun c:stamps (/ w h c r a b start)
   (if
      (and
         (setq start (list 0.0 0.0))
         (repeat r
            (repeat c
              (command "_RECTANG" "_non" start "_non" (list (+ (car start) w) (+ (cadr start) h)))
              (setq start (list (+ (car start) w a) (cadr start)))
            (setq start (list 0.0 (+ (cadr start) h b)))
Just as the above has shown, it completely works. There are other ways as well, but since you have just started using AutoLISP, I thought I'd leave some comments:
(defun c:stamps ( / _getfunc a b c h offset r start w)
    (defun _getfunc (fnc msg bit)   ;; Define a function to make use of initget.
            Initget is a function which can be used to restrict numerical user inputs:
            https://help.autodesk.com/view/OARX/2023/ENU/?guid=GUID-9ED8841B-5C1D-4B3F-9F3B-84A4408A6BBF
        (initget bit)
        (fnc msg)
    (and
            Using 'and' introduces the short-circuit evaluation, in which conditional processsing stops as soon as the first value returns nil.
            All get- functions (except getstring) returns nil upon pressing Enter
        (setq w (_getfunc getdist "\nEnter the width of the rectangle <exit>: " 6))  ;; A value of 6 (bits 2 and 4) ensure that the user enters a positive value and not 0
        (setq h (_getfunc getdist "\nEnter the height of the rectangle <exit>: " 6)) ;; Using getdist allow the user to also specify two points to define the distance.
        (setq c (_getfunc getint "\nEnter the number of columns <exit>: " 6))
        (setq r (_getfunc getint "\nEnter the number of rows <exit>: " 6))
        (setq a (_getfunc getdist "\nEnter the distance between columns <exit>: " 4))
        (setq b (_getfunc getdist "\nEnter the distance between rows <exit>: " 4))
        ;; Comment one line or the other depending on the insertion point being located at (0.0 0.0), or to a point specified by the user.
        ;(setq start '(0.0 0.0))
        (setq start (getpoint "\nSpecify point to place rectangles <exit>: "))
            (setq offset '(0.0 0.0))
            (repeat r
                (repeat c
                    (command "_RECTANG" "_non" (mapcar '+ start offset) "_non" (mapcar '+ start offset (list w h)))
                    (while (not (zerop (getvar "cmdactive"))) (command ""))     ;; This ensure that the Space/Enter key keeps getting pressed until the command is over.
        ;; Not entirely necessary, but I always use it for good practise.
                    (setq offset (list (+ (car offset) w a) (cadr offset)))
                (setq offset (list 0.0 (+ (cadr offset) h b)))
    (princ)     ;; Exit the command quitely. Always use this, good common AutoLISP programming practise for a clean command line exit.
Edited by Jonathan Handojo
Another why not draw 1 and use array ?
(defun c:stamps (/ w h c r a b pt)
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter values " "Width " 5 4 "100" "height " 5 4 "100" "Number columns" 5 4 "5" "Number rows" 5 4 "5"
"Dist between columns" 5 4 "20" "dist between rows" 5 4 "20")))
(setq w (atof (nth 0 ans))
h (atof (nth 1 ans))
c (atoi (nth 2 ans))
r (atoi (nth 3 ans))
a (atof (nth 4 ans))
b (atof (nth 5 ans))
(setq pt (getpoint "\nPick lower left point for rectang "))
(command "_RECTANG" "_non" pt "_non" (list (+ (car pt) w) (+ (cadr pt) h)))
(command "array" (entlast) "" "Rectangular" r c (+ b h) (+ a w) )
Multi GETVALS.lsp
Edited by BIGAL
I think it's more of a practice. It's their first code after all. Always good to start somewhere.
Good comment Johnathan, like the old saying crawl, walk then run. The array part can still be used.
guys,  You have been most helpful. :)
I now have further things and leads to study.
Thank You very much :)
  • Thanks 1
